BMW E30 Street/TimeAttack (DTM style control arms)
-work in progress-
  • 228 Följare
  • 129 597 Visningar
  • Uppdaterades senast 22 augusti 2018
Miuge
20 januari 2015 · 144 Inlägg
Finally we got the moped ready for the show:
http://i187.photobucket.com/albums/x281 … 07b716.jpg
http://i187.photobucket.com/albums/x281 … ef1315.jpg
..so again I had time for the car. Firstly I did some cutting to complete few welds, but also you'll see air duct for the IC radiator and rear brakes, as well as body needs to be widen couple of centimeters:
http://i187.photobucket.com/albums/x281/mice325/IMG_5806_zps2b4bc044.jpg
BMW 320i "Street-TimeAttack" (1987)
Miuge
24 januari 2015 · 144 Inlägg
Cut, create, copy, paste.. That's how a sheetmetal version of the widebody is done. Shy version of the Group5 cars..
Still a lot to do.
http://i187.photobucket.com/albums/x281/mice325/IMG_5816_zps1c6690d9.jpg
http://i187.photobucket.com/albums/x281/mice325/IMG_5823_zpsd655e434.jpg
http://i187.photobucket.com/albums/x281/mice325/IMG_5825_zps8862d905.jpg
eastmotorsport -sommar ska de va....
24 januari 2015 · 4 524 Inlägg
Snygg breddning!
Miuge
27 januari 2015 · 144 Inlägg
Tack så mycket smile
One side ready, one to do. Air duct for the radiator with 180mm hose connection and 76mm for the brakes. Not the easiest thing to do out of sheet metal, but I'm pretty happy with the result smile
http://i187.photobucket.com/albums/x281/mice325/airinlet_zpsd20a3272.jpg
Emiiilz
27 januari 2015 · 908 Inlägg
Looks cool! smile
Nissan Skyline R33 GTST "Tiger" (1994)
28 januari 2015 · 4 524 Inlägg
Tycker intaget ser grymt bra ut!
Miuge
5 februari 2015 · 144 Inlägg
Bra att ni gillar smile
Last week we took our gas turbine bike to Finnish motorcycle exhibition and we got the OpenClass 2nd price smile Not bad for a first-timer?
http://i187.photobucket.com/albums/x281 … e28e9d.jpg
This week I continued building my car, naturally... Passenger side needed an air duct too, which became as good as the other side. Here you can see the boxed subframe reinforcements:
http://i187.photobucket.com/albums/x281/mice325/IMG_5897_zps8264a4d4.jpg
A-pillars got reinforcements too with dimpled holes:
http://i187.photobucket.com/albums/x281/mice325/IMG_5894_zpsdde4985b.jpg
Miuge
12 februari 2015 · 144 Inlägg
Aluminium bits, these should keep feet still and reduce the heat radiated from the gearbox or exhaust:
http://i187.photobucket.com/albums/x281/mice325/IMG_5926pieni_zps9928db3d.jpg
Passenger side:
http://i187.photobucket.com/albums/x281/mice325/IMG_5937pieni_zps91455c9c.jpg
Senast redigerat av Mickey_ (12 februari 2015)
Renjaegarn Den som ingen turbo har får åka utan bar
12 februari 2015 · 860 Inlägg
Följer! fetaste jag sett på garaget!
Administratör för JDM Life Sweden
Toyota Supra MKIV Turbo "Supraholm" (1997)
Toyota Celica GT4 ST205 TTE WRC "Toyota Team Europe Replica" (1996)
Audi A6 Allroad "Lowroad" (2017)
Miuge
16 februari 2015 · 144 Inlägg
Jag tackar! smile
Time for a monday update.
Finally I got all the seat mounts welded and made a bracket for a hand brake, it's time for paint soon!
http://i187.photobucket.com/albums/x281/mice325/IMG_5943pieni_zps0d402db4.jpg
Driver fits and driving position is somewhat cozy and roomy, I like:
http://i187.photobucket.com/albums/x281/mice325/IMG_5958pieni_zpsd7af7430.jpg
Miuge
19 februari 2015 · 144 Inlägg
Time for the dashboard. I modified the orginal model a little bit, photoshopped how it should look like when finished and today I started to create the mold.
Sketch:
http://i187.photobucket.com/albums/x281/mice325/dashboardphotoshopsmall_zpsb9cbc386.jpg
Model covered with aluminium tape and wax:
http://i187.photobucket.com/albums/x281/mice325/IMG_5974pieni_zps2b70e60b.jpg
Gelcoat layer:
http://i187.photobucket.com/albums/x281/mice325/IMG_5977pieni_zps2bcc1cf4.jpg
Fiberglass:
http://i187.photobucket.com/albums/x281/mice325/IMG_5981pieni_zps403b7ab5.jpg
And couple of foam reinforcements:
http://i187.photobucket.com/albums/x281/mice325/IMG_5983pieni_zps2c587d4a.jpg
Tomorrow the moment of truth yikes
Senast redigerat av Mickey_ (19 februari 2015)
Oggart
19 februari 2015 · 145 Inlägg
nice work!
Miuge
21 februari 2015 · 144 Inlägg
Thanks!
Getting there.. I'm pretty happy with the mold as it's my first big fiberglass project smile Just a little bit sanding and filler into the worst spots. Also started to make foam models for the insets:
http://i187.photobucket.com/albums/x281/mice325/IMG_5991_zps94576b27.jpg
Miuge
3 mars 2015 · 144 Inlägg
Dashboard project continues..
I finished the mold yesterday, surface wasn't perfect but good enough as the final product goes to flocking:
http://i187.photobucket.com/albums/x281/mice325/11024506_1032125536803662_1725651626_o_zps1balt5k7.jpg
Then a thick layer of gelcoat into the mold:
http://i187.photobucket.com/albums/x281/mice325/IMG_6015_zps8xaeh14a.jpg
One layer of chopped type fiberglass and one layer of braid type as reinforcement:
http://i187.photobucket.com/albums/x281/mice325/IMG_6017_zpsfq0kub6j.jpg
Wilsooon
3 mars 2015 · 158 Inlägg
Sjukt coolt projekt! Ser verkligen ut att vara hög kvalitét på allt du bygger, keep it up! Vart ifrån Finland är du?
Miuge
Tack så mycket! Ja från Tammerfors, skriver på engelska när det är mycket lättare för mej än svenska big_smile
Miuge
5 mars 2015 · 144 Inlägg
Getting there.. Gelcoat had melted the paint which made the surface look strange big_smile But the result otherwise is decent, little bit of sanding and grinding.. Weight was 3kg.
http://i187.photobucket.com/albums/x281/mice325/IMG_6023pieni_zpswkk3w9ps.jpg
Senast redigerat av Mickey_ (5 mars 2015)
Miuge
7 mars 2015 · 144 Inlägg
Yesterday I got E30, E36 and E36 M3,2 spindles side by side for measuring. Gathered some useful data..
http://i187.photobucket.com/albums/x281/mice325/navat_e30e36e36m_zps2jqis68x.jpg
Miuge
10 mars 2015 · 144 Inlägg
Almost every part in this picture is already fitted, but the list of the other tasks seems endless... By the end of spring I want to drop it on it's wheels with finished bodykit! cool
http://i187.photobucket.com/albums/x281/mice325/WP_20150309_18_50_26_Pro_zpsvn8oknyq.jpg
