wolkswagen split bus type 2
Totalrenovering av vw split bus type 2 T1 RHD 1962.Elsystemet ska bytas från 6v till 12v motor från 1200cc till 1500cc framöver blir det en massa förbättringar :)
  • 337 Följare
  • 919 944 Visningar
  • Uppdaterades senast 14 april
Dr_snuggels
6 oktober 2022 · 3 517 Inlägg
då var motorn ur. avgas toppar kolvar kylning bort taget
nu ska det beställas grejer så den blir tät å går fint igen smile
https://www1.garaget.org/gallery/images/38/37069/37069-3f9857b2000d965c6499f13dead5cec8.jpg
https://www1.garaget.org/gallery/images/38/37069/37069-8e33220dec97aff83e9bae3c7e2ba46a.jpg
https://www1.garaget.org/gallery/images/38/37069/37069-5e834946c56c0d3621a43da3bf840305.jpg
https://www1.garaget.org/gallery/images/38/37069/37069-d1858b8fc734a3859756e79ce63735d9.jpg
https://www1.garaget.org/gallery/images/38/37069/37069-d3557ac4730d6acb8236b26a43f4d884.jpg
https://www1.garaget.org/gallery/images/38/37069/37069-5239e22d337925ee06ea427576bf2ee1.jpg
https://www1.garaget.org/gallery/images/38/37069/37069-c30e40e13d6e15b287122a086625f0b3.jpg
https://www1.garaget.org/gallery/images/38/37069/37069-ed52b94ecb24980b06417428c2188164.jpg
https://www1.garaget.org/gallery/images/38/37069/37069-240ebe6296f434c7198633043945c207.jpg
https://www1.garaget.org/gallery/images/38/37069/37069-f877078befd426b8e5dd9da293416e86.jpg
https://www1.garaget.org/gallery/images/38/37069/37069-46419fb6364b9065d11a480d237efb31.jpg
https://www1.garaget.org/gallery/images/38/37069/37069-3c763a1a53948ece26e62695cbfd5051.jpg
https://www1.garaget.org/gallery/images/38/37069/37069-06105e20afca964ce4e0300afd073919.jpg
https://www1.garaget.org/gallery/images/38/37069/37069-fe9a66204d499aea427e78ba83b77f86.jpg
https://www1.garaget.org/gallery/images/38/37069/37069-dbe8c0de77a04ef195a3c27eeb96196e.jpg
https://www1.garaget.org/gallery/images/38/37069/37069-a43360dee78919a6dd0e0182c4f340eb.jpg
https://www1.garaget.org/gallery/images/38/37069/37069-d455ed335b4b8fa7af2348de6979c2eb.jpg
https://www1.garaget.org/gallery/images/38/37069/37069-79ad419884063dd13cbeab69366cd051.jpg
https://www1.garaget.org/gallery/images/38/37069/37069-2c08e599f4e4150a437f629e25b53426.jpg
https://www1.garaget.org/gallery/images/38/37069/37069-bb3cf8a29c3a523a4e6653f0f300cd33.jpg
https://www1.garaget.org/gallery/images/38/37069/37069-e655d92cac1c635542c1a02a05049685.jpg
https://www1.garaget.org/gallery/images/38/37069/37069-af5655dbd87b1ce04a023da566784c46.jpg
https://www1.garaget.org/gallery/images/38/37069/37069-30327dec1938a52cff75a60f921be10f.jpg
https://www1.garaget.org/gallery/images/38/37069/37069-177ba878239ce96ddd7403864be91631.jpg
https://www1.garaget.org/gallery/images/38/37069/37069-ba80d1288f2ee33c199135aa0ca147ef.jpg
https://www1.garaget.org/gallery/images/38/37069/37069-d96695978fd2d080d814fa09a4d6b87f.jpg
https://www1.garaget.org/gallery/images/38/37069/37069-17e0df83b491f3dc8f47f33b85d47a29.jpg
https://www1.garaget.org/gallery/images/38/37069/37069-46b8c100a4e0e5e35e7bad1d5a3c0dce.jpg
https://www1.garaget.org/gallery/images/38/37069/37069-cfca9a1e7f49715c7e1340eb96da4231.jpg
https://www1.garaget.org/gallery/images/38/37069/37069-e909d910208a1c02bc9b556ea74707ea.jpg
https://www1.garaget.org/gallery/images/38/37069/37069-3b9d261dadfbaed7d646a3912a683f43.jpg
https://www1.garaget.org/gallery/images/38/37069/37069-c44fd1d5b12b2709515d52e3ef736977.jpg
https://www1.garaget.org/gallery/images/38/37069/37069-5e41ffb98e8a403a4791b1a72ecf4416.jpg
https://www1.garaget.org/gallery/images/38/37069/37069-f8b0a9739b2639ec578cc39e696dde6a.jpg
vw bubbla beetle barndoor splitbuss
tommyhjortasen
13 oktober 2022 · 1 049 Inlägg
Ser ut som ringarna läckt lite. Har du mätt spelet mellan kolv och cylinder, de motorerna kan skramla lite.
Dr_snuggels
14 oktober 2022 · 3 517 Inlägg
Ja tänkte horna cylindrarna och byta till 1600cc kolvar smile
Senast redigerat av Dr_snuggels (14 oktober 2022)
Dr_snuggels
28 november 2022 · 3 517 Inlägg
jappp bara läckt lite -.....men motorn är ju från 1968 så efter 54år så får den vara lite sliten.skramla eller rasla inget i motorn gick som en dröm smile förutom oljeläckan men det löses med nya packningar smile
Dr_snuggels
inte hänt så mycket här. väntar på delar till inredning och är sugen på att beställa detta kitt.så från 1500cc till 1600cc blir lite mer vrid och fart i kärran smile
https://www1.garaget.org/gallery/images/38/37069/37069-6b18592606b999f3d0692d29e6e44c0d.jpg
Bob-Miller
28 november 2022 · 1 308 Inlägg
Köper du de kittet får du väl vikta ner framkofångaren då den kommer skicka upp framhjulen i luften varje ggn du kliver av kopplingen...hehehehe
Dr_snuggels
ajaj blir ju massa extra jobb är det inte bättre att ja går upp i vikt smile  smile
tommyhjortasen
28 november 2022 · 1 049 Inlägg
Beställ inte innan du kollat vad ett strokerkit till 2,2 liter kostar. bör gå att finna begagnat. Veven behöver bytas och viss bearbetning av blocket, delar bör finnas begagnade då de är en populär uppgradering vad jag sett i motortidningar.
Dr_snuggels
29 november 2022 · 3 517 Inlägg
går ja upp så mycket så drar det med sig mer grejer som skivbromsar/byta till bubbla vlåda drivaraxlar måste sänkas då det blir helt annan vinkel.så ja kommer hålla men till typ orginal hk ja blir ju lite lite mer nu.kan i framtiden kanske bygga om den till nått mycket värre smile detta räcker gott och väl när man har redutionsaxlar och man varvar sönder motorn
Dr_snuggels
1 december 2022 · 3 517 Inlägg
toppar och fördelar förgasaren hamnade i ett bad. låter do ligga där ett tag så dom blir rena å fina tills motorn ska, sättas ihop smile
https://www1.garaget.org/gallery/images/38/37069/37069-aad5943a9754677c91b6fd6772c70056.jpg
https://www1.garaget.org/gallery/images/38/37069/37069-2e3de32bcf02030f0da9740b31283a3d.jpg
https://www1.garaget.org/gallery/images/38/37069/37069-4ab80b5ade7d0974c3a80674b1a1f20d.jpg
https://www1.garaget.org/gallery/images/38/37069/37069-4205b252cb43351e20dc23d23218f01f.jpg
Dr_snuggels
13 december 2022 · 3 517 Inlägg
var och titta på nya splitbussen hmm nja ja vet inte
https://www1.garaget.org/gallery/images/38/37069/37069-8c40651c1f57cd564b42f73757a9a71e.jpg
https://www1.garaget.org/gallery/images/38/37069/37069-81b4382e0f226540bde6fb559cef3018.jpg
https://www1.garaget.org/gallery/images/38/37069/37069-96b0a098f559126c858a4bc8fe2d36ad.jpg
Senast redigerat av Dr_snuggels (13 december 2022)
Dr_snuggels
19 december 2022 · 3 517 Inlägg
beställde dessa små godingar i maj idag döck dom hem 🙂
https://www1.garaget.org/gallery/images/38/37069/37069-260b3a345912162ec70e1b0adf173036.jpg
https://www1.garaget.org/gallery/images/38/37069/37069-decb731dbb742738bbbaac68820e1431.jpg
volvoqq Lastbilsmekaniker
20 december 2022 · 5 135 Inlägg
Bättre sent den aldrig, beställde en sak på Volvo för något år sedan glömde bort det för delen var restad tog nästan ett år innan delen helt plötsligt hade anlänt😂
Dr_snuggels
20 december 2022 · 3 517 Inlägg
oj var ju ingen stress me dessa är skruvar till panelerna på insidan. Men ville ju ha dom så man kan snygga till insidan 🙂
Giuseppe
15 januari 2023 · 363 Inlägg
Dr_snuggels
15 januari 2023 · 3 517 Inlägg
Giuseppe skrev:
https://www.linkedin.com/posts/activity-7020303595229048833-nZMs?utm_source=share&utm_medium=member_ios
Inspiration till nästa projekt smile
kan inte så sad
Giuseppe
16 januari 2023 · 363 Inlägg
https://www1.garaget.org/gallery/images/168/167987/167987-3780f2dac382325b1156d554a0bdc091.jpg
kan inte så sad
Dr_snuggels
17 januari 2023 · 3 517 Inlägg
kan inte så sad
jaa den har ja sett så fränt bygge
Dr_snuggels
31 januari 2023 · 3 517 Inlägg
så är grejerna på väg https://www1.garaget.org/gallery/images/38/37069/37069-89b86547fdf1bc4a37c2c7ed6cc5e65e.jpg
Dr_snuggels
2 februari 2023 · 3 517 Inlägg
https://www1.garaget.org/gallery/images/38/37069/37069-68ee3fb11c13ebc4dc98ecf4a7fef4bf.jpg
https://www1.garaget.org/gallery/images/38/37069/37069-8e15d843a05cfc0e38609f6a2c12a180.jpg
https://www1.garaget.org/gallery/images/38/37069/37069-4de45a908978ec9fa9c4af4b4fcacca5.jpg
https://www1.garaget.org/gallery/images/38/37069/37069-e7ce8c1ff2a7a1c8d1ba9eb0612d8c45.jpg
