Volvo 142 16V b230
Planning to turn my ocean green Volvo 142 into a clean rust free 16v B230 mildly tuned car that?ll keep up with traffic and do well on long adventures to discover surf around the Baltic in Sweden in style. Any tips are welcome in both Swedish or English. budget to the build is 100k Kronor. We?ll see where that gets me.
  • 55 Följare
  • 21 372 Visningar
  • Uppdaterades senast 14 juni 2021
qbomani
2 juni 2021 · 24 Inlägg
Inken skrev:
är den klar nu ,, vad har du för växellåda,,
The gear box on this one is an M47, thinking of eventually changing but it works great for now. It’s a daily driver after all.
Volvo 142 "Green Machine" (1972)
qbomani
https://www1.garaget.org/gallery/images/233/232879/232879-6216f2f95441fb16de468d488a8b7538.jpg
Inken
4 juni 2021 · 523 Inlägg
ok då är det bare att ut å köre hele sommarn,
Fiat 126 "gotlandsfiaten" (1975)
FredGaute
5 juni 2021 · 860 Inlägg
Super NICE!
Roberto33
7 juni 2021 · 1 Inlägg
Wow cool build. I have a 142 as wel and want to do a similar build. Already have a m47 gearbox and searching for a b230 8v.
My question is: did you changed something about the oilpan? Or is the clearence enough on the subframe because you put it in upright position in combo with self-designed enginemounts?
kind regards,
Robert
qbomani
14 juni 2021 · 24 Inlägg
kind regards,
Robert
Hi Robert
I ended up using the b20 oil pan with custom engine mounts made by Yoshifab in the states. The mounts allows for enough clearance with no necessary modifications to the frame, however the B230’s high-flo oil pump has to be shortened to allow it clear the shallower pan.
Also with some slight modifications to the Volvo M40 crossmember it’s an easy fit with an m47. Most 142’s have pre thread holes that were meant to line up with overdrive boxes.
Senast redigerat av qbomani (14 juni 2021)
