1,8t 20v swap i Golf 2
Denna vintern byggs motorn om, blir smidd motorn och en gt2871r turbo. Blir kanske snabbaste golf 2an i kommunen.
  • 61 Följare
  • 29 002 Visningar
  • Uppdaterades senast 31 december 2020
goffen621
31 oktober 2020 · 46 Inlägg
Motorn påväg ut.
https://www1.garaget.org/gallery/images/234/233714/233714-c230e67ed1423839216d24ee43770cf3.jpg
https://www1.garaget.org/gallery/images/234/233714/233714-eaf1cb2133f66fcfdf35d356a06b97b2.jpg
https://www1.garaget.org/gallery/images/234/233714/233714-24b316c15bd77b74e59326a59a63834b.jpg
https://www1.garaget.org/gallery/images/234/233714/233714-26a7b7a4ac9ae52dbd010f9a3162eaa5.jpg
Lite tvätt
https://www1.garaget.org/gallery/images/234/233714/233714-10c8531f353bd7ca6205f7dfcbf0f1f0.jpg
https://www1.garaget.org/gallery/images/234/233714/233714-3ff509083882e08dfe64331c91831fee.jpg
https://www1.garaget.org/gallery/images/234/233714/233714-2f8653a362401e3fc8031c6a2701f631.jpg
Skruvar isär toppen
https://www1.garaget.org/gallery/images/234/233714/233714-da7e613ab92d222d132cdf13fe3ea8b6.jpg
https://www1.garaget.org/gallery/images/234/233714/233714-a7170ddd97a755d643d78d5aad5151b3.jpg
Slår ut och i med nya styrningar, mycket glapp på avgas sidan.
https://www1.garaget.org/gallery/images/234/233714/233714-47722ea88c744778b40b0beae42ef912.jpg
https://www1.garaget.org/gallery/images/234/233714/233714-46681ba5f41ce90d0a6ba87b8c2844b4.jpg
https://www1.garaget.org/gallery/images/234/233714/233714-1f36bf1e47fca84f7343c1150e7c4f94.jpg
https://www1.garaget.org/gallery/images/234/233714/233714-d3d18768ae64bae3d014a786325c3c5f.jpg
https://www1.garaget.org/gallery/images/234/233714/233714-be0bd00781ca8c295e10ddfbc4c402a9.jpg
Mäter ventilskaften för att kolla slitaget.
https://www1.garaget.org/gallery/images/234/233714/233714-9bf242d9b0b85d9bb3850fbb738314a0.jpg
Kollar så alla är raka sen slipas dem.
https://www1.garaget.org/gallery/images/234/233714/233714-e71db896e72aed84dce91cf060e9277a.jpg
https://www1.garaget.org/gallery/images/234/233714/233714-477592bfeb3d9fe11d5c386b0e6d8598.jpg
https://www1.garaget.org/gallery/images/234/233714/233714-1e481e30ed213da99b2e805f2a378afc.jpg
Blocket är nu borrat och toppdeckat. Ingen bild på borrning, fått de gjort av en firma.
https://www1.garaget.org/gallery/images/234/233714/233714-920bb07d21bcaa0ac2674e9dfc62c6a4.jpg
https://www1.garaget.org/gallery/images/234/233714/233714-560c9557a540e40353ad32da710326df.jpg
https://www1.garaget.org/gallery/images/234/233714/233714-a5d5663779c8d2760545d0eda51c0a7a.jpg
Viktat in stackar, kolvbult och kolv.
https://www1.garaget.org/gallery/images/234/233714/233714-9500603659c2c2aa621c8dfb9241d3e7.jpg
https://www1.garaget.org/gallery/images/234/233714/233714-504120905e1b73cb4b73b4934679102c.jpg
https://www1.garaget.org/gallery/images/234/233714/233714-5d7b4ab43121d59db25e5551d0badcdf.jpg
goffen621
Glasblästrat blocket och gått igenom alla gängor med gängtapp. Redo för att målas nu.
https://www1.garaget.org/gallery/images/234/233714/233714-6a66e8ed625a140938586837eee7a65b.jpg
https://www1.garaget.org/gallery/images/234/233714/233714-068201194ebeecb9b2290cfec7204a23.jpg
Monterat 280mm skivor med tillhörande ok.https://www1.garaget.org/gallery/images/234/233714/233714-b6b9ddfe1edcd84727d08c9d2d49d5a0.jpg
https://www1.garaget.org/gallery/images/234/233714/233714-dfc1b9018929414156564f38b8edfd1e.jpg
Monterat strongflex i fram och bakvagn.
https://www1.garaget.org/gallery/images/234/233714/233714-bc1ac40203a0d36da8537294f3ea3bb8.jpg
https://www1.garaget.org/gallery/images/234/233714/233714-b8f14d1d64e00b9c65fb876a84d113e6.jpg
https://www1.garaget.org/gallery/images/234/233714/233714-b5bb563f440a7f11c9ed428789274a79.jpg
https://www1.garaget.org/gallery/images/234/233714/233714-6a4c1fa5c59c991d52bc9e6274b3ec9c.jpg
Alla tiders
DKW_
7 november 2020 · 74 Inlägg
Grett med sån där tillgång till maskiner. Vad blir det för turbo?
goffen621
29 december 2020 · 46 Inlägg
Blocket målat
https://www1.garaget.org/gallery/images/234/233714/233714-48470fa92af61f9145e686a4e35649b8.jpg
https://www1.garaget.org/gallery/images/234/233714/233714-0373b3339fcb3aa98e1ad1987533b94a.jpg
Mäter upp ramlagerspelet
https://www1.garaget.org/gallery/images/234/233714/233714-ce80096d357eb4296c839f78b07ca1d6.jpg
https://www1.garaget.org/gallery/images/234/233714/233714-1fbba808b8cc7bd221232d416dc32495.jpg
https://www1.garaget.org/gallery/images/234/233714/233714-33a93b63963f44e125e4ab64aaa7d4d1.jpg
Sen i med veven
https://www1.garaget.org/gallery/images/234/233714/233714-d9964f2778630fed5727891cce88d379.jpg
Mäter upp axialspelet
https://www1.garaget.org/gallery/images/234/233714/233714-1ab3790ff41efa3ed55a2467e7eb4de8.jpg
Kollar så veven är rak
https://www1.garaget.org/gallery/images/234/233714/233714-30dc74413ecaa6e6207a7c1c4ed216a2.jpg
Mäter och slipar in ringarna
https://www1.garaget.org/gallery/images/234/233714/233714-71becbde48aa68ab11b8627995e142da.jpg
Sen mätte jag vevstakslagerspel och banka i kolvarna
https://www1.garaget.org/gallery/images/234/233714/233714-68c335105d8c5e480ba2ed6d1bbc459e.jpg
https://www1.garaget.org/gallery/images/234/233714/233714-5dc6a5818ead3739fac44f8182c0e774.jpg
Sen frästes ventilsätena
https://www1.garaget.org/gallery/images/234/233714/233714-fb32e4852004bad2ffed3ed6ea1b808b.jpg
Satte i ventilerna
https://www1.garaget.org/gallery/images/234/233714/233714-94e785e63544a6272fb87a77af9ac5c5.jpg
https://www1.garaget.org/gallery/images/234/233714/233714-aed23eddba92627510038220e1692251.jpg
Kollade så dem höll tätt
https://www1.garaget.org/gallery/images/234/233714/233714-52907bf0296bd4d19cf744038dfcbd09.jpg
https://www1.garaget.org/gallery/images/234/233714/233714-2676d85087f3ba8821973a278ed3fe12.jpg
Sen i med kammarna
https://www1.garaget.org/gallery/images/234/233714/233714-fe9028ce377a8782b8fb18418315a61f.jpg
https://www1.garaget.org/gallery/images/234/233714/233714-c44383054902e41ca02253195d275717.jpg
https://www1.garaget.org/gallery/images/234/233714/233714-c305f084d8ef7a78536fc1c72c18220a.jpg
https://www1.garaget.org/gallery/images/234/233714/233714-1ce435da667885d67e84b61542694a67.jpg
goffen621
Garrett 2871r, håller på med att bygga grenrör nu så kommer lite bilder på de i veckan.
goffen621
Delat lådan för montering av quaife diff
https://www1.garaget.org/gallery/images/234/233714/233714-1f460bba27b8e47d5370080152ed0dbe.jpg
https://www1.garaget.org/gallery/images/234/233714/233714-e24f01a47e342964262a05dd99565c0c.jpg
https://www1.garaget.org/gallery/images/234/233714/233714-d5d5899a61441db83d3e3e16bef97efe.jpg
Borrar ut nitarna till kronhjulet från gamla diffen.
https://www1.garaget.org/gallery/images/234/233714/233714-9feabbccda47b5d42c3304827e4b68aa.jpg
På med de på nya diffen och nya lager
https://www1.garaget.org/gallery/images/234/233714/233714-96bca7d1efe10b6e215cf10479b9e45c.jpg
https://www1.garaget.org/gallery/images/234/233714/233714-8552a3851b4d275b784504196c125dff.jpg
https://www1.garaget.org/gallery/images/234/233714/233714-6ce5b2ca040bc2a9b98acb760d5a5264.jpg
Mäter upp vilket shims som behövs för att shimsa in diffen
https://www1.garaget.org/gallery/images/234/233714/233714-a948f1a7cb468344574b0f6af76ee0ec.jpg
Mäter upp rätt shims
https://www1.garaget.org/gallery/images/234/233714/233714-ebb3ef21a1b5fa9d45fef96b8cfbbd56.jpg
Sen ihopa med skiten igen
https://www1.garaget.org/gallery/images/234/233714/233714-fbaa08aa531098cb09a79a9d999b8c04.jpg
https://www1.garaget.org/gallery/images/234/233714/233714-c5e42ef9a1829c3f8a9068fe74cda865.jpg
https://www1.garaget.org/gallery/images/234/233714/233714-f5f83c5d909dfc61e0d7256195a551be.jpg
Färdig låda med nya lager, packboxar och diff
https://www1.garaget.org/gallery/images/234/233714/233714-968e44785e00939b6238ce17b7d338dc.jpg
https://www1.garaget.org/gallery/images/234/233714/233714-52c3c8281d3ba348409556952d8c2f16.jpg
Monterat koppling, sachs performance med enkelmassesvänghjul från bartek
https://www1.garaget.org/gallery/images/234/233714/233714-6172233a875b421b9108adee62a68167.jpg
https://www1.garaget.org/gallery/images/234/233714/233714-605d46360c33134b3aeb169474ec7da8.jpg
https://www1.garaget.org/gallery/images/234/233714/233714-5540a0a5a6f5ff18696571f5e2df2d9f.jpg
Motor och låda ihopa
https://www1.garaget.org/gallery/images/234/233714/233714-22364e53d063c8287cba5597bebb947e.jpg
Provmonterat motorn i bilen, gjort nya motorfästen igen, passa bra.
https://www1.garaget.org/gallery/images/234/233714/233714-0990df745cc76e661c6a4fdc52261b67.jpg
fish Allfixare
29 december 2020 · 1 475 Inlägg
Grymt!
goffen621
Byggt grenrör idag.
Började med att göra en jigg till var jag ville ha turbon och satte upp i en dålig reservtopp jag hade liggandes.
https://www1.garaget.org/gallery/images/234/233714/233714-94c56d56e17952a87025bc457d6409da.jpg
https://www1.garaget.org/gallery/images/234/233714/233714-818bae20e03e5fe299c8dc8ed47a1c26.jpg
https://www1.garaget.org/gallery/images/234/233714/233714-211cb22718de497f61f8f2a79a1b879a.jpg
Gjorde sen en kollektor, va ett jävla jobb med de.
https://www1.garaget.org/gallery/images/234/233714/233714-a302aa64bbe4f094d89a7ec09e1de6e8.jpg
https://www1.garaget.org/gallery/images/234/233714/233714-3f0adb5b248c566ba6dd3c5cd2482f37.jpg
https://www1.garaget.org/gallery/images/234/233714/233714-24c7c1d932d82e20a8d953c3d8062412.jpg
https://www1.garaget.org/gallery/images/234/233714/233714-7c75e284312c7b5b89e607ff8c2190ca.jpg
Sen växte de fram ett grenrör
https://www1.garaget.org/gallery/images/234/233714/233714-db43fa812610c94ebcd5e9ade72642db.jpg
https://www1.garaget.org/gallery/images/234/233714/233714-17ceb391819dd772e9b4552151c7d990.jpg
https://www1.garaget.org/gallery/images/234/233714/233714-58e7f33a0b382fcef8d67740624d32e4.jpg
https://www1.garaget.org/gallery/images/234/233714/233714-2ad78427ed6d06209544538a48889303.jpg
https://www1.garaget.org/gallery/images/234/233714/233714-d59afdf3672b23b3b807a75a84611da5.jpg
https://www1.garaget.org/gallery/images/234/233714/233714-e7c022fb73ad60f560615c0d5048a230.jpg
https://www1.garaget.org/gallery/images/234/233714/233714-0c495fc7979450a82d41ae04cfd09d8f.jpg
https://www1.garaget.org/gallery/images/234/233714/233714-46a074547781359ff1c13d3b92a91ce5.jpg
https://www1.garaget.org/gallery/images/234/233714/233714-71bbaf44079f762cac1f41aff26ed9fb.jpg
https://www1.garaget.org/gallery/images/234/233714/233714-3f1a090859812a12690e10c963a5ac89.jpg
Nästan klart, lite svets kvar sen trycktesta de så de håller tätt.
goffen621
31 december 2020 · 46 Inlägg
Flänsen hade vridit sig lite av värmen så planade av den
https://www1.garaget.org/gallery/images/234/233714/233714-57e30dc49f4e0d9ffa9249fc3723429f.jpg
https://www1.garaget.org/gallery/images/234/233714/233714-67299e0b4347fdf5c35fe0b4955cc94c.jpg
Sweeper Rostskadad
22 juni 2021 · 194 Inlägg
Färdig än? xD
2 frågor,
är ditt dragläge långt nere när du släpper kopplingen?
Hur är det att gasa i högre hastigheter med quaife diffen? slingrar sig bilen eller går rakt?
Hur är det vid omkörningar?
rudak
5 augusti 2023 · 30 Inlägg
Hur har d gått ?
6 augusti 2023 · 17 478 Inlägg
rudak skrev:
Hur har d gått ?
Medlem Goffen621 var senast inloggad 2021. Bilen har bytt ägare 2022 men är bes & i trafik.
"En röd sedan av årsmodell 1990 som är i trafik. Växellådan är manuell och motorn är på 190 hk och drivs med etanol. Vi uppskattar den årliga körsträckan till 3 022 mil."
