Hybrid_
Forum- och sitemoderator
1 april 2023
· 17 465 Inlägg
Kopplar det inte ihop extrabatteriet?
EDIT:
"The auxiliary battery supplies power for a limited time if system charging or battery voltage drops. The battery control module monitors system voltage. If voltage reaches a low point, the auxiliary battery relay closes to connect the battery to the vehicle fuse blocks."
Senast redigerat av Hybrid_ (1 april 2023)
