Volvo Duett Renovering
Detta är min renovering på Duett Pickisen:)
  • 2 Följare
  • 4 020 Visningar
  • Uppdaterades senast 4 december 2018
Hugo_Wendel
24 oktober 2018 · 9 Inlägg
Detta är min renovering på Duett pickisen smile
https://www1.garaget.org/gallery/images/227/226383/226383-144475a919a5d3c06d85a6c90b1280b1.jpg
https://www1.garaget.org/gallery/images/227/226383/226383-3e7b0ba0ab05fa071d9e5df9f1681c53.jpg
https://www1.garaget.org/gallery/images/227/226383/226383-b983998428b7c6f6082cec410c62700c.jpg
https://www1.garaget.org/gallery/images/227/226383/226383-9b07b7f7821778c9d35dfe90fcd5c719.jpg
https://www1.garaget.org/gallery/images/227/226383/226383-e5a6602ad25b088288db782508b33c20.jpg
https://www1.garaget.org/gallery/images/227/226383/226383-58aef57d67f1dea30da0a700f9abc365.jpg
https://www1.garaget.org/gallery/images/227/226383/226383-014e512004ff3464ca92ca5c013aa9b7.jpg
https://www1.garaget.org/gallery/images/227/226383/226383-79ebadb591d2a883d68b6cfe51dae525.jpg
https://www1.garaget.org/gallery/images/227/226383/226383-d1fac1d8ed12b63e72305f3a2561d1b0.jpg
https://www1.garaget.org/gallery/images/227/226383/226383-121d76affa4488b3fa907f0c5fb7423a.jpg
https://www1.garaget.org/gallery/images/227/226383/226383-f0d6f8d2716c050bd45b2a35be809057.jpg
https://www1.garaget.org/gallery/images/227/226383/226383-0db2f817f329a0dad020ec5349598ac4.jpg
https://www1.garaget.org/gallery/images/227/226383/226383-d2ba4c0d7fb699ed8dd954c61c2e6a85.jpg
https://www1.garaget.org/gallery/images/227/226383/226383-ede2ededfbaa235369d5762e9865aecc.jpg
https://www1.garaget.org/gallery/images/227/226383/226383-2be43d900e272a21b5d58be484a40c6d.jpg
https://www1.garaget.org/gallery/images/227/226383/226383-53c0248fef8d0d5e8c19cf96892922ba.jpg
https://www1.garaget.org/gallery/images/227/226383/226383-e91d49295e0489b71da85033426c656a.jpg
https://www1.garaget.org/gallery/images/227/226383/226383-2943af47d9080bf3375c566337d4e6fe.jpg
https://www1.garaget.org/gallery/images/227/226383/226383-4ae027899a8dd54ac484b15a82f44779.jpg
https://www1.garaget.org/gallery/images/227/226383/226383-fcd35c9b45fd5f4db319cdbfe536263e.jpg
https://www1.garaget.org/gallery/images/227/226383/226383-3a7ea354cf1ea40248755f20dc316124.jpg
https://www1.garaget.org/gallery/images/227/226383/226383-938a48a78f463aa366a4920260ff43ec.jpg
Hugo_Wendel
25 oktober 2018 · 9 Inlägg
Jag fick kapa upp ett hål i torped sidan för att den såg rostig ut vi just ett ställe sad                                                      Sen provmonterade jag skärmen och insåg att det var ett stort hålrum så att det blir och byta hela torpedsidan.
https://www1.garaget.org/gallery/images/227/226383/226383-d0fbade07b8182163b7d6deeeb44d5d5.jpg
https://www1.garaget.org/gallery/images/227/226383/226383-5bff93c639e12a7f8f7e14b2a7a60ddb.jpg
Senast redigerat av Hugo_Wendel (25 oktober 2018)
Hugo_Wendel
30 oktober 2018 · 9 Inlägg
Kapade ur lite ifrån kylarfästet på en annan pv front och svetsade på min pv front:)
För att duett fronten var tydligen högre.
https://www1.garaget.org/gallery/images/227/226383/226383-9bf42c7362b9546cf9f71bcd7014613b.jpg
Senast redigerat av Hugo_Wendel (30 oktober 2018)
Hugo_Wendel
2 december 2018 · 9 Inlägg
Svetsade på en plåt på torpedsidan sedan när jag provmonterade skärmen då tog tröskeln i, så blev att kapa ut den o fälla in.
https://www1.garaget.org/gallery/images/227/226383/226383-8babd5f78bca8161b28f1f88a90784cf.jpg
https://www1.garaget.org/gallery/images/227/226383/226383-19dc21552288c337efdc6da009196bed.jpg
https://www1.garaget.org/gallery/images/227/226383/226383-1a28032f602cf3ef56fb930a20897db6.jpg
Hugo_Wendel
4 december 2018 · 9 Inlägg
Började med att kapa ur torpedsidan.
https://www1.garaget.org/gallery/images/227/226383/226383-30e256262ed9944bfdd5dcccc483d349.jpg
Sedan slipade jag ner insidan och målade för att det inte ska fortsätta rosta:)
https://www1.garaget.org/gallery/images/227/226383/226383-7166e572b42a2f1398048cfe372b763d.jpg
Bockade en 90graders plåt som jag svetsade på som torpedsidan ska sitta emot.
https://www1.garaget.org/gallery/images/227/226383/226383-8f589c7e5115fa9b56eea37812bc85c2.jpg
Kapade ut ovan för torpedväggen på torpedsidan för var rosthål.
https://www1.garaget.org/gallery/images/227/226383/226383-54e2006cb75ce004885a6bbc4beab1fd.jpg
Gjorde plåten som skulle sitta där.
https://www1.garaget.org/gallery/images/227/226383/226383-267390b65bc6a904102202335a2076bf.jpg
Sen punktade jag fast den:)
https://www1.garaget.org/gallery/images/227/226383/226383-fcf311ca5273c32295a26593090c4d45.jpg
Slipade ner den och såg resultat.
https://www1.garaget.org/gallery/images/227/226383/226383-7f01ab33b306d6d728c1487735942209.jpg
Efter att svetsat och slipat ner svetsarna så mätte jag ut var skärmen skulle sitta och markerade var jag skulle borra hål.
https://www1.garaget.org/gallery/images/227/226383/226383-7dba6e419bf82e94a69cb49640b98c84.jpg
Kapade tröskelen för att skärmen tog i så passformen blev dålig,har även gjort detta på andra sidan.
Sedan slog jag in den tills skärmen passa o svetsade ihop det igen:)
https://www1.garaget.org/gallery/images/227/226383/226383-e41d0a579ae12827c446ca0284aca0f5.jpg
Slipade svetsar.
https://www1.garaget.org/gallery/images/227/226383/226383-0e06177e6619e769f5c9c9a3a06ba771.jpg
Sen satte jag på ena skärmen med bra passform:)
https://www1.garaget.org/gallery/images/227/226383/226383-a6ad8e0716be99252b3661b0a4966bf1.jpg
https://www1.garaget.org/gallery/images/227/226383/226383-acf1b66117bfdb5ff09de61be8b885f8.jpg
Hugo_Wendel
Tog ner lådan och målade den:)
https://www1.garaget.org/gallery/images/227/226383/226383-cc8098faf67186876a0d90d0cf1ac23c.jpg
Hittade rost i golvet ovanför växelådsbalken, kapade ut det o svetsade dit en ny plåt
https://www1.garaget.org/gallery/images/227/226383/226383-169d18c6ebd0dffd6ae9f3a341d6d256.jpg
https://www1.garaget.org/gallery/images/227/226383/226383-33b1d9f111e72f09a5b8b4b928eb1d86.jpg
Gjorde en plåt som ska täck igen gamla hålet till korta spaken då det ska va lång spak:)
https://www1.garaget.org/gallery/images/227/226383/226383-7913ed63cdf7470e9224353d50703711.jpg
Svetsat dit plåten.
https://www1.garaget.org/gallery/images/227/226383/226383-2db0cacb48b4700149c886af2e071460.jpg
Lådan uppe, kardanen åkte upp dagen efter;)
https://www1.garaget.org/gallery/images/227/226383/226383-d8a285788c51e06b30f8b010283f07ef.jpg
Dålig bild men spaken på nu åxåsmile
https://www1.garaget.org/gallery/images/227/226383/226383-8a72c4ef7c7a79282c2f48c29ee8f8df.jpg
