Väcka gamle pv:n till liv
Väcka gamle PV:n till liv . Stoppa i lite nyare teknik än det som fanns -62
  • 193 Följare
  • 127 698 Visningar
  • Uppdaterades senast 17 november 2021
kissen
16 januari 2017 · 124 Inlägg
https://www1.garaget.org/gallery/images/10/9512/9512-1f8f52019366342befd76d14c4ef88dc.jpg
https://www1.garaget.org/gallery/images/10/9512/9512-12a79d08b73a9ca6c3db4a3e3d31bee7.jpg
https://www1.garaget.org/gallery/images/10/9512/9512-84cc1b6aa6dc4c6a9e5ecb7ce7ee443b.jpg
https://www1.garaget.org/gallery/images/10/9512/9512-1b104c8e4667a625cfd81957d9b3ab0c.jpg
https://www1.garaget.org/gallery/images/10/9512/9512-7556085f2674632ee6ca6544a8844d9d.jpg
https://www1.garaget.org/gallery/images/10/9512/9512-e55442c58bd52f8cdb6ffd30745aa519.jpg
https://www1.garaget.org/gallery/images/10/9512/9512-a85181e02693d5f06c91b8cfdac24ec2.jpg
https://www1.garaget.org/gallery/images/10/9512/9512-521a59406e5a70a2df99872a8c968b51.jpg
https://www1.garaget.org/gallery/images/10/9512/9512-ede03e309303854537187bc16e7a0dd0.jpg
https://www1.garaget.org/gallery/images/10/9512/9512-301349f9f73ec20698e95ad5ae1c5ec6.jpg
https://www1.garaget.org/gallery/images/10/9512/9512-dd289b0db1d07843c08aa459e6664b9f.jpg
https://www1.garaget.org/gallery/images/10/9512/9512-a341f1037f9ba046603631cdee6e8bec.jpg
https://www1.garaget.org/gallery/images/10/9512/9512-8c8361dabea12460a294802828992da5.jpg
https://www1.garaget.org/gallery/images/10/9512/9512-659b25a23ffc4a9f46d2a7b8c8feedd8.jpg
https://www1.garaget.org/gallery/images/10/9512/9512-e00bbf4cb256c7865abfef948f9aa832.jpg
https://www1.garaget.org/gallery/images/10/9512/9512-1bd731b08bd398d7dffe549337f3a5dc.jpg
https://www1.garaget.org/gallery/images/10/9512/9512-98d70da1aeb8c239294a4880e9a1ce09.jpg
https://www1.garaget.org/gallery/images/10/9512/9512-35887bddcb2bae5a0a25a4614f7b87f9.jpg
kissen
22 januari 2017 · 124 Inlägg
https://www1.garaget.org/gallery/images/10/9512/9512-5379f4723c8975b2e45d55c1a1000d36.jpg
https://www1.garaget.org/gallery/images/10/9512/9512-22325d92c3ffe2a018d88e5f3c85b2f8.jpg
https://www1.garaget.org/gallery/images/10/9512/9512-326f163711f1aa4dec2adf16354b8490.jpg
Mercedes2
23 januari 2017 · 49 Inlägg
grymt fint. fram o bakvagn Blir?
kissen
24 januari 2017 · 124 Inlägg
Bakvagn är BMW E 39 -02 touring , fram 940 fjäderben avkapade .påsvetsade coiloverhylsor från TXR .Coiloverben från E46 .
kissen
Växellådstunnel kom på plats igår ( glömde ta kort ) men det kommer nog en bild ikväll.
Snart dax för lite rörbockning fram som ska bli fjädertorn.
Mercedes2
24 januari 2017 · 49 Inlägg
Har du kapat ur framvagnsbalk o annat också? även bak då spårvidden blir väl fel??
Ska själv bygga min egen snart. 57. Så din bil ger näring. ..
kissen
25 januari 2017 · 124 Inlägg
Framvagnsbalken är från en 240 som under tiden har modifierats mer och mer ,Spårvidden fram har anpassats efter vidden bak då den är given , den är ungefär som en 740 , valde mellan 740 ns stela eller bmws bakvagn när bygget planerades.
Senast redigerat av kissen (25 januari 2017)
kissen
Tunnel börjar sitta på plats .
https://www1.garaget.org/gallery/images/10/9512/9512-f0519634134f7a02567394b04e9efa2d.jpg
steffe66
25 januari 2017 · 23 Inlägg
http://www1.garaget.org/gallery/images/10/9512/9512-f0519634134f7a02567394b04e9efa2d.jpg
Det blir kanonfint.
kissen
26 januari 2017 · 124 Inlägg
https://www1.garaget.org/gallery/images/10/9512/9512-e941c3cc9e91864e0f8a6676e7bff231.jpg
Försöker mäta ut vart fjädertallriken ska vara .
kissen
https://www1.garaget.org/gallery/images/10/9512/9512-7387860dfa30befad623d2cdcb4b529a.jpg
kissen
https://www1.garaget.org/gallery/images/10/9512/9512-a7a388ba01cf27a19ad9e79912dca76f.jpg
Synpunkter på skärmvallsningen ? jag vill ha den kvar andra inte ,dessutom ska skärmen bräddas 70 mm.
https://www1.garaget.org/gallery/images/10/9512/9512-8aeebe0bdf28526069e14049a5735d91.jpg
Senast redigerat av kissen (26 januari 2017)
V_O-L-V_O
26 januari 2017 · 555 Inlägg
Snyygt jobbat o riktigt intressant bygge!!! Hur är spårvidden bak jmf med orginal PV? Skärmvalsningen ser riktigt nice ut men du kommer att bredda också?
Volvo V90 3.0 "Jessie" (1998)
Volvo 144GL "GOLDIE" (1974)
kissen
Tack  tack . har för mig att spårvidd nu är något mer än en 740 ( kommer inte ihåg siffran nu ) ja måste bredda skärmarna ca 65-70 mm / sida.
// Martin
FredGaute
26 januari 2017 · 860 Inlägg
Fint PV bygg, passe avansert, likevel passe original utvendig, liker det!
Hvilken motor?
jarleb
26 januari 2017 · 914 Inlägg
Denne blir rå smile   følger  smile
V_O-L-V_O
27 januari 2017 · 555 Inlägg
Kan du berätta mer om framvagnen, A-arm (hemmagjord?) balken osv (bilder?)
kissen
27 januari 2017 · 124 Inlägg
https://www1.garaget.org/gallery/images/10/9512/9512-f981b74073713127e9ac8bac0b72844b.jpg
https://www1.garaget.org/gallery/images/10/9512/9512-85685daa9b1b3b3b804c93b33149102f.jpg
Börjat mäta och kapa ,slipat in rören som ska hålla i fjädertornet.
kissen
28 januari 2017 · 124 Inlägg
Framvagnsbalken är i grunden en standard volvo 240 som är av smalnad utanför rambenen och ditsvetsade plattor upp mot karossen. urgröpt för sumpen fick inte plats .
TXR`s länkarm med coiloverhylsa E46 coilover  volvo 940 spindel.
https://www1.garaget.org/gallery/images/10/9512/9512-2d900efbb216b85d3d77b63df7234daf.jpg
kissen
29 januari 2017 · 124 Inlägg
https://www1.garaget.org/gallery/images/10/9512/9512-71b83e96dcd4410026f10c617ac7fc30.jpg
https://www1.garaget.org/gallery/images/10/9512/9512-70e4d06c0ba9b83604c7df0b3474783d.jpg
Fått dit övre infästningen, ska förstärkas och snyggas till lite innan jag är nöjd.
