it_mutt skrev:
The main difference between the v1.3a and v1.4b chips is that the v1.4b offers the ability to go to a low power 'sleep' type mode. This is great for installations where it is preferred to keep the ELM327 connected to the vehicle (fleet applications, etc.).
There are also several improvements to protocol support which advanced users may find useful (control of the CAN silent mode, 4800 baud ISO/KWP, etc.).
Please note:
The ELM327 v1.4b is a mature product that has been replaced by the v2.1. We continue to offer this version for our customers that still need it, but we advise you to seriously consider using the v2.1 for any new designs.
ELM327 - OBD to RS232 Interpreter (v2.1) - (our 'latest and greatest' version)
The latest version of our ELM327 integrated circuit provides all that the v1.3a and v1.4b products do, and also has:
a 512 byte RS232 transmit buffer
many improvements for speed and reliability
an Activity Monitor, for going to low power and waking
many new Programmable Parameters and AT commands
frequency matching to prevent false CAN sends while searching
the ability to process Response Pending replies
and many, many more improvements. If you were considering buying the v1.4b, then you will like the new v2.1 IC much better. Pricing remains the same as for the v1.4b:
2.1 är alltså den senaste. 1.4 finns helt enkelt inte, utan är mest troligen en 1.4b (1.5 finns inte heller fast säljare på ebay hävdar det)
Tack för utförlig info it_mutt!
Jag fann källan till den på Elm electronics: http://elmelectronics.com/obdic.html.
Dessvärre tillverkar och säljer de endast chipen (de integrerade kretsarna) till modulen.
Jag sökte lite på ställen som sålde hela moduler. Fann inga svenska återförsäljare.
På Amazon dyker de upp en del som säger sig vara 2,1, men det verkar inte stämma om man får tro kommentarsfältet:
The device functions just fine with the Torque app, but unfortunately it is NOT version 2.1...when it connects with the app, its identified as ELM v1.5. Sorry...
(se: http://www.amazon.com/Latest-Version-EL … B00GP8DG20).
Här dyker alltså den icke existerande Ver. 1.5 upp igen (det finns även svenska ÅF som saluför Ver. 1,5).
Förklaringen till detta finns nog också på Elm electronics' hemsida:
If you want a 'ready-made' circuit (ie with Bluetooth, USB, WiFi, etc.) then you will have to search the web for it. Some companies use integrated circuits that try to mimic our products, so be careful (as some times, you just get your money's worth).
Det enda ställe jag lyckades finna som, förhoppningsvis, verkligen säljer Ver. 2.1 är AliExpress (
Aliexpress började som en avstickare till Alibaba.com, världens största mötesplats för leverantörer i Kina och importörer från hela världen.
- se: http://www.scandinasian.se/importguiden/aliexpress/; artikeln i fråga, ELM327 Ver. 2.1, ser ut att tillverkas av ett företag i Guangdong, Kina http://www.aliexpress.com/item/Latest-V … 59089.html).
Saken är dock den, om man skall vara noggrann, att för att kunna importera elektronik krävs att de uppfyller Europeiska certifieringskrav, vilket de, enligt länken från importguiden ovan, sällan gör (Aliexpress riktar sig främst mot USA, Sydamerika, Ryssland och Sydostasien):
Det är få, om ens några, leverantörer på Aliexpress som handlar med produkter som lever upp till Europeiska certifieringskrav i händelse av att en importör från EU skulle titta förbi. Nedan följer en lista på några produkter som kräver certifiering:
a.) Elektronik (CE, RoHS)
b.) Leksaker (EN71)
c.) Kemiska produkter (REACH)
Att ta hem en liten modul är väl egentligen inte mycket att bråka om kan man tycka men det vore toppen om det finns någon som vet var man kan få tag på en äkta Ver. 2.1 inom Sverige eller EU.
Alla tips och förslag är intressanta!
Senast redigerat av bilberra (5 augusti 2014)
