26 september 2024
Hej igen,
Jag valde att byta batterit förra veckan. Felmeddelanden kvarstår tyvärr.. nu ser jag dock endast "City Safety service" som alltid felar direkt vid motorstart, och "SRS airbag" som ibland kommer upp (Inte DSTC).
Läste ut felkoderna:
BCM-U002855 - Vehicle Communication Bus A System Programming Failures. Not Configured
BCM-U045286 - Invalid Data Received From Restraints Control Module. Bus Signal / Message Failures. Signal Invalid
ABS-C006364 - ABS-C006364 Yaw Rate Sensor. Algorithm Based Failures. Signal Plausibility Failure
BCM-U015100 - Lost Communication With Restraints Control Module. General Failure Information. No Sub Type Information
BCM-U405241 - Invalid Data Received From Restraints Control Module. System Internal Failures. General Checksum Failure
CEM-B102581 - Transponder Bus Signal / Message Failures. Invalid Serial Data Received
CEM-B11D453 - Low Speed Collision Mitigation By Braking Disabled. System Programming Failures. Deactivated
SRS-U002888 Vehicle Communication Bus A. Bus signal / Message Failures. Bus Off
SRS-U023500 Lost Communication With Closing Velocity Module. General Failure Information. No Sub Type Information
SRS-U100456 Software Incompatibility With Closing Velocity Module. System Programming Failures. Invalid / Incompatible Configuration
CVM-U002800 Vehicle Communication Bus A. General Failure Information. No Sub Type Information
CVM-U041568 Invalid Data Received From Brake Control Module. Algorithm Based Failures. Event Information
CVM-U03004A Internal Control Module Software Incompatibility. System Internal Failures. Incorrect Component Installed
CVM-U300066 Control Module. Algorithm Based Failures. Signal Has Too Many Transitions / Events
Har raderat felkoderna och gjort en BMS reset, men felmeddelanden på displaypanelen kvarstår (City Safety & Airbag).
Sannolikt ett underliggande problem med någon sensor?? Typ ABS / City-safety kamera/sensor? Har inte fysiskt undersökt kablaget då jag inte riktigt vågar pilla själv.
Inte heller testat att kalibrera om styrvinkelsensorn med min felkodläsare, men det kanske är långtsökt?
Kanske inte kan slippa ta in den till en auktoriserad verkstad om det krävs en mjukvaruuppdatering eller så..
Några tankar?
Senast redigerat av Saj98 (26 september 2024)
