10036
min kenwood kdc m6024 vägrar läsa skivor
skogstomte
21 oktober 2008
ja har en kenwood huvudenhet inköpt ca 2003 som har funkat skitbra ända tills nu i höst,när den varit oanvänd ett tag(månad) så läser den ej cd utan visar MEC ERROR eller TOC ERROR. någon som varit med om det eller vet någe tricks för å fixa det?
Fire And Silk
2 254 Inlägg
21 oktober 2008
Se om detta hjälper dig lite iallafall:
The messages shown below display your systems
condition.
Eject/ EJECT: No disc magazine has been loaded in the changer. The
disc magazine is not completely loaded.E01
➪ Load the disc magazine properly.
No CD in the unit.
➪ Insert the CD.
No Disc/ NO DISC: No disc has been loaded in the disc magazine.E02
➪ Load a disc into the disc magazine.
TOC Error/ TOC ER: No disc has been loaded in the disc magazine.E04
The CDÏ is quite dirty. The CD is upside-down. The CD
is scratched a lot.
➪ Clean the CD and load it correctly.
E-05: The CD is upside-down.E05
➪ Load the CD correctly.
Blank Disc/ BLANK: Nothing has been recorded on the MD.E10
No Track/ NO TRACK: No tracks are recorded on the MD, although it has a
title.E11
E-15: Media was played that doesn’t have data recorded that
the unit can play. E15
➪ Use media that has data recorded that the unit can
play.
No Panel/ NO PANEL: The faceplate of the slave unit being connected to this
unit has been removed.E30
➪ Replace it.
E-77: The unit is malfunctioning for some reason.E77
➪ Press the reset button on the unit. If the "E-77" code
does not disappear, consult your nearest service
center.
Mecha Error/ MECHA ER:
Something is wrong with the disc magazine. Or the unit
is malfunctioning for some reason.E99
➪ Check the disc magazine. And then press the reset
button on the unit. If the "Mecha Error"/ "MECHA ER"
code does not disappear, consult your nearest
service center.
Hold Error/ HOLD ER:
The protective circuit in the unit activates when the
temperature inside the automatic disc changer exceeds 60°C
(140°F), stopping all operation.E0d
➪ Cool down the unit by opening the windows or turning on
the air conditioner. As the temperature falls below 60°C
(140°F), the disc will start playing again.
NO NAME: Attempted to display DNPS during the CD play having no disc
names preset.E51
Load/ LOAD: Discs are being exchanged in the Disc changer.E57-1
Reading: The unit is reading the data on the disc.E57-2
NO ACCESS: After setting it in the Disc Changer, DNPP was done without
having it been played at least 1 time.E58
IN (Blink): The CD player section is not operating properly.E59
➪ Reinsert the CD. If the CD cannot be ejected or the display
continues to flash even when the CD has been properly
reinserted, please switch off the power and consult your
nearest service center.
Senast redigerat av -Mackan- (21 oktober 2008)
Det viktiga är inte att ha rätt, utan att straffa de som har fel. ''Gustav Svensson''
Fire And Silk
2 254 Inlägg
21 oktober 2008
Har du testat med en ''rengörningsskiva'' ? Eller så har helt enkelt läsaren sagt upp sig.
Här ser du rengöringsskivan den har som en borste som borstar av laserhuvudet varje varv:
http://img.game.co.uk/images/gameware/cddvdlenscleaner.gif
skogstomte
21 oktober 2008
jag har öppnat den,gjort ren lasern med tops och testat alla skivor jag har och den enda den läser e en Springsteen men då hakkar den till förbannelse, går de att få tag i laser så man kan byta själv ?
