BMW E30 Street/TimeAttack (DTM style control arms)
-work in progress-
  • 228 Följare
  • 129 986 Visningar
  • Uppdaterades senast 22 augusti 2018
Miuge
11 april 2013 · 144 Inlägg
Hi everybody!
Me and two friends of mine started a team called Magnus Racing a few years ago, now it's time to make it more official.
We lived in the same city in Finland and we still have our garages down there. Everyone has their own car to build, aim is to go faster without looking bad.
Like us on Facebook to see those other projects and more updates:
http://www.facebook.com/magnusracingteam
This thread is for my BMW E30 built to streetlegal TimeAttack racer.
Everything started from this, orginal BMW 320i 1987:
http://i187.photobucket.com/albums/x281/mice325/keskuvaa005.jpg
In few months I had bought and done a lot of stuff and car looked like this:
18" wheels                                   http://i187.photobucket.com/albums/x281 … asa007.jpg
D2 coilovers and 325i disc brakes  http://i187.photobucket.com/albums/x281 … aan011.jpg
Headers                                        http://i187.photobucket.com/albums/x281 … C03164.jpg
Typ188 differential                       http://i187.photobucket.com/albums/x281 … ivusta.jpg
Powerflex bushes                          http://i187.photobucket.com/albums/x281 … saa006.jpg
Sparco seat and Momo wheel        http://i187.photobucket.com/albums/x281 … taa002.jpg
By that time I had made all the chassis work to make it rust free, good subject to start a bigger project.
BMW was hold in the garage for few years and I only scraped some stuff together:
M30 engine                                  http://i187.photobucket.com/albums/x281 … rsu007.jpg
E36 M3 spindles                           http://i187.photobucket.com/albums/x281 … uva141.jpg
Had a cheap coilover kit                http://i187.photobucket.com/albums/x281 … s09009.jpg
E34 M5 rear axle                          http://i187.photobucket.com/albums/x281 … G_4774.jpg
Recent years I've done more or less, at least I've tried wink
First fitting for the engine             http://i187.photobucket.com/albums/x281 … G_4937.jpg
Something was missing                http://i187.photobucket.com/albums/x281 … G_5396.jpg
Looking better                              http://i187.photobucket.com/albums/x281 … G_6414.jpg
Twin charging components           http://i187.photobucket.com/albums/x281 … 000622.jpg
E46 steering rack                         http://i187.photobucket.com/albums/x281 … 000849.jpg
6-speed ZF                                  http://i187.photobucket.com/albums/x281 … 000975.jpg
Test wheels                                 http://i187.photobucket.com/albums/x281 … 3ff646.jpg
Roll cage work in progress            http://i187.photobucket.com/albums/x281 … a3afad.jpg
Battle of axles E30 vs. E34          http://i187.photobucket.com/albums/x281 … 501abc.jpg
Pedalbox fitted                             http://i187.photobucket.com/albums/x281 … e0e5dc.jpg
Seat and steering wheel re-located   http://i187.photobucket.com/albums/x281 … 05feeb.jpg
http://i187.photobucket.com/albums/x281/mice325/slide_zpsab5c1a8c.jpg
All pictures can be found from photobucket:
http://s187.photobucket.com/user/mice32 … ry/?page=1
Highlights from garaget.org:
http://www.garaget.org/?car=291564
Our team facebook page:
Thanks for watching, more updates coming soon!
Också fattar och skriver lite svenska, men allt i Facebook ska skrivas på engelska! big_smile
Senast redigerat av Miuge (1 februari 2018)
BMW 320i "Street-TimeAttack" (1987)
Miuge
17 april 2013 · 144 Inlägg
Got BBS RF wheel centres today, they're from 8x17" ET40 wheel:
http://i187.photobucket.com/albums/x281/mice325/wheelcentres_zps1af3a21d.jpg
Fitted them to my friend's car which has 325mm discs with Wilwood Superlite calipers, needed 15mm spacer to fit.
I'm planning to buy same discs (E46 M3) and Cayenne/Touareg 6-piston calipers in front. There won't be too much space:
http://i187.photobucket.com/albums/x281/mice325/IMG_6618_zps62b8e3ed.jpg
Also made little room to rear seat area so I can make the new shock towers.
From this:
http://i187.photobucket.com/albums/x281 … 1ce5f7.jpg
To this:
http://i187.photobucket.com/albums/x281 … 6a4d8c.jpg
PHrnfeldt Sheik Yerbouti
17 april 2013 · 1 899 Inlägg
Ser väldigt trevligt ut!
"Vi er dem de andre ikke må lege med".
m5portal.com
m3portal.com
gromitSWE
18 april 2013 · 1 677 Inlägg
Prem lagd! smile
Miuge
20 april 2013 · 144 Inlägg
Tack! smile
I had to make more room for the rear axle as it didn't fit as high as I wanted, next step is to modify body beams if that's not enough.
Otherwise there would be problems with trailing arm and output shaft angles with desired drive height.
http://i187.photobucket.com/albums/x281/mice325/IMG_6636_zps0cbcdd77.jpg
http://i187.photobucket.com/albums/x281 … 55d59a.jpg
New plate allowing even more lift of the axle if needed, now there's about 4cm space above the carrier:
http://i187.photobucket.com/albums/x281/mice325/IMG_6646_zps113477aa.jpg
Miuge
22 april 2013 · 144 Inlägg
Today postman brought this quick release/snap off hub for steering wheel, it would have been very hard to climb in and out of the car when the rollcage is finished with the door X-brace.
http://i187.photobucket.com/albums/x281/mice325/IMG_6650_zps8b124242.jpg
http://i187.photobucket.com/albums/x281/mice325/snapoff_zps00a34c89.jpg
Now I'm waiting my custom K-Sport coilover kit, it's based on the Circuit -model, but customized at the factory to my needs.
Front coilovers are E36 M3 type and rears E34 type which are a lot shorter than E36 or E30 shock.
They should arrive soon.. tongue
Miuge
26 april 2013 · 144 Inlägg
Coilover order came today, thanks for K-Sport Finland for an easy and fast transaction!
Looking good cool
http://i187.photobucket.com/albums/x281/mice325/IMG_6664_zps41dea7f1.jpg
http://i187.photobucket.com/albums/x281 … 93b91b.jpg
http://i187.photobucket.com/albums/x281/mice325/IMG_6670_zps713c2853.jpg
I need to design topmounts to the front with 4-bolt fastening, which allows me to make caster adjustment into the chassis. Also rear end topmounts need a little bit of modifying, thinking of spherical bearing instead of solid mounting.
Now I got all the parts to finish the rollcage, lot's of work on the way!
Miuge
2 maj 2013 · 144 Inlägg
Started with the front end last weekend, now it starts to take form.
This was the beginning, only showing approximate location of the top:
http://i187.photobucket.com/albums/x281 … 1746c7.jpg
Took this picture today, other half almost ready:
http://i187.photobucket.com/albums/x281/mice325/IMG_6678_zps0cd52696.jpg
And another:
http://i187.photobucket.com/albums/x281 … 86b427.jpg
Placing of the roll cage tube:
http://i187.photobucket.com/albums/x281/mice325/IMG_6689_zps29bde20b.jpg
Also made a 3D model of the front top mount, just needs to be machined:
http://i187.photobucket.com/albums/x281/mice325/ylapaa_etuu_zps92367f47.jpg
Miuge
13 maj 2013 · 144 Inlägg
Started with the rear end, but ended up to cut a lot metal off.. Pics coming soon.
Designing the shock tower:
http://i187.photobucket.com/albums/x281/mice325/WP_001161_zps111d375e.jpg
Finally found the brake calipers in affordable price. Porsche Cayenne Brembos 6- and 4-piston calipers:
http://i187.photobucket.com/albums/x281/mice325/cayenne_brembo_zps47bbe299.jpg
And E46 M3 front discs:
http://i187.photobucket.com/albums/x281/mice325/front_brake_zpscb13ebdf.jpg
Miuge
20 maj 2013 · 144 Inlägg
Time for a little update.
Worked with the rear end a couple of days, lots of cutting and welding new structure.
Axle is now 5cm higher than orginal mounts would allow, that should be enough. Only little sheet metal work to do.
Looking empty, again:
http://i187.photobucket.com/albums/x281/mice325/WP_001218_zps3945d9de.jpg
Almost there:
http://i187.photobucket.com/albums/x281/mice325/WP_001230_zpsac9836bd.jpg
Miuge
24 maj 2013 · 144 Inlägg
Massive brakes? Guess does the caliper fit with the E36 king pin? Nope, needs "a little" modification too roll
http://i187.photobucket.com/albums/x281/mice325/WP_001248_zps4ecd3abe.jpg
Compared to 1,5liter bottle:
http://i187.photobucket.com/albums/x281/mice325/WP_001250_zps91c95d73.jpg
Ingen som vill kommentera? Bra eller anus?big_smile
Victor_Ahlander
24 maj 2013 · 203 Inlägg
Jävlar vilket häftigt bygge, prem lagd!
Ceasarsalladen G4Z Racing
24 maj 2013 · 132 Inlägg
Först tänkte jag, ah det bromsoket var ju inte överdrivet stort men sen när andra bilden kom....
Ja jävlars vilka bromsar!
Najs bromsar och najs bygge! Kämpa på smile
Titta gärna in på www.g4z-racing.com om du är intresserad av vad jag skruvar med!
Bmw E36 320i byggs om till banbil!
Victor_Ahlander
25 maj 2013 · 203 Inlägg
Jag tänkte PRECIS likadant tongue
Miuge
3 juni 2013 · 144 Inlägg
Dom är ju ganska manliga big_smile
Here comes the update part:
Not much progress with the car last days due to working all day, but I have to try this week. And next week we'll go to Gatebil Mantorp, as usual  cool
But, I've done little modeling and measuring in my 'billet steel rocker arm' project. Bought a new orginal rocker arm and got it measured at job.
http://i187.photobucket.com/albums/x281/mice325/IMG_1275_zps86088fa4.jpg
Maybe we'll get something like this:
http://i187.photobucket.com/albums/x281/mice325/vippandeeros_zps83e6fbda.jpg
http://i187.photobucket.com/albums/x281 … 8bc6be.jpg
Also bought a new fuel cell, 60liter JAZ, which will be placed just about down there:
http://i187.photobucket.com/albums/x281/mice325/WP_001277_zps408cc323.jpg
Check out our facebook page, there should be some updates of BMW E21 project soon roll
Miuge
9 juni 2013 · 144 Inlägg
Wasn't satisfied of the rear seat area design I made earlier, so I made it again and it became much better I think. Looks a bit more orginal and more simple:
http://i187.photobucket.com/albums/x281/mice325/WP_001282_zpsae71e020.jpg
Some slot to be welded:
http://i187.photobucket.com/albums/x281 … 79b933.jpg
Also got shock towers and half of the inner wheel archs done:
http://i187.photobucket.com/albums/x281/mice325/WP_001305_zps4ff33018.jpg
Miuge
21 juli 2013 · 144 Inlägg
Not much happened this summer, but today I continued with the rollcage.. Also rear shock towers are finished.
Fitting the pipes:
http://i187.photobucket.com/albums/x281/mice325/WP_001398_zps7120e149.jpg
Dropped the cage for welding:
http://i187.photobucket.com/albums/x281 … 75837f.jpg
More coming soon, keep in touch! roll
Miuge
11 augusti 2013 · 144 Inlägg
Some welding.. What do you think? Not much experience, but I think it's good enough:
http://i187.photobucket.com/albums/x281/mice325/WP_001543_zps98374d2b.jpg
Decided to put a pair of extra pipes to the cage:
http://i187.photobucket.com/albums/x281/mice325/WP_001546_zpscf305ee2.jpg
Next week should be more productive, I dream of finishing the rollcage, we'll see cool
11 augusti 2013 · 1 899 Inlägg
Ser skitbra ut!
m5portal.com
m3portal.com
Miuge
6 september 2013 · 144 Inlägg
Ta-daa!
http://i187.photobucket.com/albums/x281/mice325/IMG_2602_zps98f128bb.jpg
http://i187.photobucket.com/albums/x281/mice325/IMG_2615_zpse30cd6e5.jpg
http://i187.photobucket.com/albums/x281 … 91e8c7.jpg
Also bought a nice differential and propeller shaft, which are durable enough, at least I hope so.. big_smile
