BMW E30 Street/TimeAttack (DTM style control arms)
-work in progress-
  • 228 Följare
  • 130 000 Visningar
  • Uppdaterades senast 22 augusti 2018
Miuge
1 september 2014 · 144 Inlägg
It's been a busy summer and no time with the car, but now we've got lot's of motivation to continue smile I did some planning for the next summer and decided to use STD M30 bottom end with low boost. Found a cheap one, cylinder head still missing..
http://i187.photobucket.com/albums/x281/mice325/WP_002904_zps764ac775.jpg
We also did some research of blow-off valves or dump valves and noticed cheap ones had serious quality problems and those well known brands cost a million.
I spent days modelling our own product which finally became even lighter and more compact compared to similar valve! And the price tag should be no problem for anyone looking for a dump valve smile
Yesterday we started machining the first prototypes (raw version) for testing, let us know what do you think!
http://i187.photobucket.com/albums/x281/mice325/rev23purp_zps24b08bbb.png
http://i187.photobucket.com/albums/x281/mice325/IMG_5087_zps20a5f132.jpg
Follow the progress in https://www.facebook.com/magnusracingteam
BMW 320i "Street-TimeAttack" (1987)
OlleOlaglig 2Fast4You
1 september 2014 · 499 Inlägg
These kind of projects is what makes the visit of the forum worth it, good luck! smile
Ford Sierra 2.0T "Wannabe Cosworth" (1988)
Miuge
30 september 2014 · 144 Inlägg
Thanks for your comment! smile
Today I had a feeling, that I must continue with the project..
I dig the front piece from the garage and finished mountings for the oil cooler and radiator. Bottom of the radiator will lay on two rubber pads.
http://i187.photobucket.com/albums/x281/mice325/syksyjatkuu_zps20886ba9.jpg
Welded upper mounts:
http://i187.photobucket.com/albums/x281/mice325/WP_003060_zps70d0602e.jpg
Earlier I started to fit the brake calipers, finally made them fit "deep" enough, needed some more cutting of the king-pins.. 17in wheels will be no problem I think smile RF centres needed a 20mm spacer:
http://i187.photobucket.com/albums/x281/mice325/WP_003064_zps780b2489.jpg
Miuge
4 oktober 2014 · 144 Inlägg
Rear brakes only need adapter plates to fit, measured all critical dimensions today. RF wheel centre might fit even without spacer:
http://i187.photobucket.com/albums/x281/mice325/IMG_5404_zpsa6055288.jpg
Adapter will be made of aluminium and it has threaded holes:
http://i187.photobucket.com/albums/x281/mice325/jarruadapteri_zpse4bfe52a.png
We also tried DIY anodizing in our dump valve:
http://i187.photobucket.com/albums/x281 … ca7244.jpg
http://i187.photobucket.com/albums/x281 … bb044d.jpg
http://i187.photobucket.com/albums/x281 … dcd123.jpg
http://i187.photobucket.com/albums/x281/mice325/IMG_5398_zps171218c7.jpg
JoarH
5 oktober 2014 · 129 Inlägg
Damn this is a great project! Keep up the good work!
Miuge
11 oktober 2014 · 144 Inlägg
Here's a picture of front king pin modifications:
http://i187.photobucket.com/albums/x281/mice325/IMG_5493_zps49e60bee.jpg
Yesterday I got my rear brake adapters and I anodized them dark grey:
http://i187.photobucket.com/albums/x281/mice325/IMG_5560_zps4e44aa87.jpg
I'm planning to buy Ferodo DS2500 brake pads, haven't heard any good about EBC (though I have a set of greenstuff in my bicycle big_smile).. Any other suggestions about pads?
Finally after anodizing our dump valve got laser engraved texts in it's cap:
http://i187.photobucket.com/albums/x281/mice325/pieniproto_zps8d6257ea.png
Miuge
12 november 2014 · 144 Inlägg
Recently I made a place for the IC radiator, that was pretty much the only place because I didn't want to stuff anything extra to the front. Water tank and pump will be placed to the trunk also.
http://i187.photobucket.com/albums/x281/mice325/WP_003124_zpseb45ed62.jpg
Tuggummimannen Taggad
12 november 2014 · 1 507 Inlägg
Satan vilket schysst bygge! Följer!
Volvo 740 GLT 16v "Olga" (1990)
BMW 318is Turbo "Liket" (1993)
JoarH
12 november 2014 · 129 Inlägg
Looking good!
vw4lifee
12 november 2014 · 75 Inlägg
kan man besikta med kylaren där??
Miuge
13 november 2014 · 144 Inlägg
Ja men om du har bränslesystemet i baklucka då måste du bygga separat låda för bränsletanken, så jag måste bearbeta det.
Miuge
20 november 2014 · 144 Inlägg
Fuel tank is now isolated from the cabin, I wasn't really satisfied with the previous version but this turned out better smile
Horizontal tubes support rear wing and vertical ones sway bar fastening points:
http://i187.photobucket.com/albums/x281/mice325/IMG_5666_zps2c48986d.jpg
Like our page, it motivates us to work hard! Thank You! smile
Miuge
3 december 2014 · 144 Inlägg
Don't ask how many hours I've spent with this thing and why is it so complicated.. big_smile
http://i187.photobucket.com/albums/x281/mice325/remotefillerthing_zps814d0f16.jpg
eastmotorsport -sommar ska de va....
4 december 2014 · 4 524 Inlägg
Very nice work!
Emiiilz
6 december 2014 · 908 Inlägg
This looks great big_smile I like the blow off valve you build, hope it work fine ++ for that one.
Nissan Skyline R33 GTST "Tiger" (1994)
Miuge
11 december 2014 · 144 Inlägg
Thank you! Blow off valve works fine, two of them has been tested in a turbo Miata and RB26 powered Nissan smile
Today I got my single wiper conversion work, it's pretty compact package compared to orginal system:
http://i187.photobucket.com/albums/x281/mice325/th_MVI_5690_zpsaiwr3tci.mp4
Then I spent few minutes to sketch dashboard, next I'll make a plywood model:
http://i187.photobucket.com/albums/x281/mice325/IMG_5693_zps3b6ed2c8.jpg
Miuge
17 december 2014 · 144 Inlägg
Here's air intake for cabin heater, I'm going to use an universal heater unit. Water should run to direction of the blue arrow and red arrow shows path for air:
http://i187.photobucket.com/albums/x281/mice325/ilmaranni_zpsda3f847b.jpg
IC is also now mounted, heater will be bolted on top of it:
http://i187.photobucket.com/albums/x281/mice325/IMG_5707_zpsca72cb62.jpg
Wood workshop! Plywood model almost done, today I must check if the gear stick has enough room, you can't remember everything at once... roll
http://i187.photobucket.com/albums/x281/mice325/IMG_5712_zps8afc17e3.jpg
Iceen -Iceen Garage-
21 december 2014 · 772 Inlägg
Awesome man! smile
Sponsorer: Spacer.se
ICEEN GARAGE
Följ gärna min projekttråd: http://www.garaget.org/forum/viewtopic. … 15&p=1
Chevrolet S10 "Stance truck" (1999)
Miuge
23 december 2014 · 144 Inlägg
Thanks! smile
Yesterday chassis had a quick wash with water and in some parts we used sand:
http://i187.photobucket.com/albums/x281/mice325/IMG_5722_zpsf6452d5f.jpg
http://i187.photobucket.com/albums/x281/mice325/IMG_5728_zpsdfb89c03.jpg
Miuge
11 januari 2015 · 144 Inlägg
No major progress with the car this year, yet, just completed some unfinished welds and made necessary reinforcements for the roll cage:
http://i187.photobucket.com/albums/x281/mice325/IMG_5793_zpsa068d3ec.jpg
Our gas turbine bike has taken some time again as we are taking it to a Finnish bike show in the end of the month, few updates and polishing:
http://i187.photobucket.com/albums/x281/mice325/Project%20Jatkettu/messukettu_pieni_zpsd884a5fc.jpg
