6492
Ets
2 Inlägg
21 juli 2007
Har en s70r, o ibland kommer det upp ETS när jag kör.
Vad är det för ngt?
Mvh Johan
Yellow bug!
1 640 Inlägg
22 juli 2007
volvo-s70r skrev:
Vad är det för ngt?
Mvh Johan
Provat att Googla? wink Första träffen blev:
"Answer
Hello Julian,
Firstly I should say that unfortunately this case is important so you should get the car repaired as soon as possible.
ETS means Electronic Throttle System, the problem is regarding that part. The part is located in the inlet side of the engine that means it is a part of inlet side of the emission system, also there is one part called mass air flow sensor it is located also at the inlet side of the engine. There are two parts also called oxygen sensors (one of them is front oxygen sensor the other one is rear) located on the exhaust, they are parts of the emission system. If you drive this car more with ETS problem, you may face to face oxygen sensor and mass air flow sensor problems also.
Firstly, please take the car to the service, the ETM (Electronic Throttle Module) should be cleaned, if the cleaning procedure will not be enough, it should be replaced with new one. Its price approx 750 USD. It has also a Software (ETM Software).
Briefly, go to service as soon as possible. At the service, the car will be checked via computer, and the Diagnostic Trouble Codes will be taken from the Engine Control Module. In my opinion they are regarding ETM according to your clues. Firstly, cleaning (if not enoughh) may be replacing...
Regards... "
Ännu vet ingen hur gammal en Volkswagen kan bli! :)
