8205
Motorbeteckningar samt lite info, Opel Astra F, G och H.
562 Inlägg
16 november 2008
Motorbeteckningar samt lite info, Opel Astra F.
Bensin
Modell, motorbeteckning, blandningssystem, hk, anmärkning
1,4, 14NV, 2E3 förgasare, 75hk
1,4, 14SE, Multec-M, 82hk
1,4, C14NZ, Multec, 60hk
1,4, C14SE, Multec-M, 82hk
1,4, X14NZ, Multec, 60hk
1,4-16V, X14XE, Multec-S, 90hk
1,6, 16LZ2, Multec, 75hk
1,6, 16SV, Förgasare, 82hk
1,6, C16NZ, Multec, 75hk
1,6, C16SE, Multec-M, 100hk
1,6, X16SZ, Multec, 71hk
1,6, X16SZR, Multec, 75hk
1,6-16V, X16XEL, Multec-S, 100hk
1,8, C18NZ, Multec, 84hk
1,8, C18SEL, Simtec 56.5, 115hk
1,8, C18XE, Simtec 56, 125hk
1,8, C18XEL, Simtec, 115hk
1,8, X18XE, Simtec 56.5, 115hk
2,0, 20NE, Motronic 4.1, 115hk
2,0, 20SEH, Motronic 4.1, 130hk
2,0, C20NE, Motronic 4.1,115hk
2,0-16V, C20XE, Motronic 2.8, 150hk, Astra GSI
2,0-16V, X20XEV, Simtec 56/56.5, 136hk
Diesel
1,7, 17D, Diesel, 66hk
1,7, 17DR, Diesel, 57hk
1,7, 17DT, Turbodiesel, 82hk
1,7, X17DT, T-Diesel VE4, 82hk
1,7, X17DTL, T-Diesel VE4, 68hk
Motorbeteckningar samt lite info, Opel Astra G .
Bensin
1,2-16V, X12XE, Motronic M1.5.5, 65hk
1,2-16V, Z12XE, Motronic M1.5.5, 75hk, ersatte X12XE till modellår 2001
1,4-16V, X14XE, Multec-H , 90hk
1,4-16V, Z14XE, Multec-H, 90hk, ersatte X14XE till modellår 2001
1,6-8V, X16SZR, Multec-F, 75hk
1,6-8V, Z16SE, Multec-S, 84hk
1,6 CNG, Z16YNG, Multec-H, 97hK
1,6-16V, X16XEL, Multec-H, 101hk
1,6-16V, Z16XE, Multec-H, 101hk, ersatte X16XEL till modellår 2001
1,6-16V TWINPORT, Z16XEP, Multec-H, 103hk
1,8-16V, X18XE1, Simtec 70, 116hk
1,8-16V, Z18XE, Simtec 71, 125hk, ersatte X18XE1 till modellår 2001
1,8-16V, Z18XEL, Simtec 71, ?
1,8-16V, C18SEL, Simtec 56.5, ?
2,0-16V, X20XEV, Simtec 70, 136hk
2,0-16V, X20XER, Simtec 70, 160hk, OPC 1999-2002
2,0 TURBO, Z20LET, Motronic M1.5.5 , 192hk, OPC 2002-2003
2,0 TURBO, Z20LET, Motronic M1.5.5 , 200hk, OPC 2003-2004
2,2-16V, Z22SE, GMPT15, 147hk,
Diesel
1,7-8V TD, X17DTL, EDC MSA 15M,68hk
1,7-16V DTI, Y17DT, HDRC,75hk
1,7-16V CDTI, Z17DTL, EDC 15 C7,80hk
2,0-16V DI, X20DTL, EDC MSA 15M,82hk
2,0-16V DTI, Y20DTH, EDC MSA 15M,101hk
2,2-16V DTI, Y22DTR, PSG 16,125hk
Motorbeteckningar samt lite info, Opel Astra H.
Bensin
1,2, Z12XEP, Motronic ME7.6.x, 80hk
1,4, Z14XEL, Motronic ME 7.6.x, 75hk
1,4 TWINPORT, Z14XEP, Siemens MS 75, 90hk
1,6, Z16XER, Siemens MS 75, 115hk
1,6 TWINPORT, Z16XEP, MT35E, 105hk
1,6 TURBO, Z16LET, Motronic ME 7.6.x, 180hk
1,8, Z18XE, Simtec 71.6, 125hk
1,8, Z18XER, Simtec 75, 140hk
2,0 TURBO, Z20LEL, Motronic ME7.6.x, 170hk
2,0 TURBO, Z20LER, Motronic ME7.6.x, 200hk
2,0 TURBO, Z20LEH, Motronic ME7.6.x, 240hk, Astra OPC
Diesel
1,3 CDTI, Z13DTH, Multijet 602, 90HK
1,7 CDTI, Z17DTL, EDC 16C9, 80HK
1,7 CDTI, Z17DTH, EDC 16C9, 100HK
1,7 CDTI, Z17DTJ, DECOREE 01, 110HK
1,7 CDTI, Z17DTR, DECOREE 01, 125HK
1,9 CDTI, Z19DTL, EDC 16C9, 100HK
1,9 CDTI, Z19DT, EDC 16C9, 120HK
1,9 CDTI, Z19DTJ, EDC 16C9, 120HK
1,9 CDTI, Z19DTH, EDC 16C9, 150HK
Obs! Med reservation för skrivfel.
9-5 Aero Sedan -05
562 Inlägg
26 november 2008
Opel Astra F Växellådor
CR = Close ratio
14NV, C14NZ och X14NZ: T.o.m. 1993, F10. F.o.m. 1994, F13.
14 SE och C14SE: T.o.m. 1994, F10. F.o.m. 1994, sportmodeller F13 eller F15CR.
X14XE och C16NZ: F13
C16SE: F13, F13CR eller F15CR.
X16SZ och X16SZR: F13 eller F13CR.
X16XEL: F15 eller F15CR.
C18NZ, C18XE, C18XEL och C20NE: F16, F16CR, F18 eller F18CR.
X18XE: F18CR.
C20XE: F20CR eller F18CR.
X20XEV: F18.
Senast redigerat av micke-opel (26 november 2008)
9-5 Aero Sedan -05
10 287 Inlägg
26 november 2008
Den trycker jag in i motordatatråden. Tack för infon!
Göran
Moderator
(Groucho Marx).
562 Inlägg
26 november 2008
Glad att jag kan hjälpa till smile
9-5 Aero Sedan -05
