12602
Göra om 3ds Max modell till Cad
417 Inlägg
5 augusti 2009
Har en modell gjord i programmet 3ds Max.
Finns det en möjlighet att översätta den eller nå´t liknande så man kan använda den
i ett CAD-program?
Och med CAD-programmet sedan fräsa ut en modell i divinycell.
Mvh/ Jocke
224 Inlägg
6 augusti 2009
Från 3ds hjälpen.
When you export an AutoCAD drawing file, you convert your 3ds Max objects into AutoCAD objects. Because AutoCAD doesn't support animation, the exporter produces objects in a static state defined by the current frame set by the time slider.
If you used layers, instances, or colors to organize objects in the scene, that structure is maintained when the model is exported.
Exported objects with modifiers assigned to them are affected by the current state of the modifier. For instance, if the Taper modifier assigned to a box is turned off, the exported scene shows a non-tapered box.
NoteLayers created in 3ds Max are not exported to AutoCAD.
NoteExporting to an AutoCAD R14 drawing file is not supported. If you are working with AutoCAD R14, export to 3DS or DXF file format.
hoppas detta hjälper dig lite.
417 Inlägg
9 augusti 2009
tack smile
mvh/Jocke
