9153
Sony Vaio få igång bluetooth?
1 854 Inlägg
29 april 2010
Har köpt en Sony Vaio nyligen och får inte igång bluetooth.
Nån som vet om man måste göra nått för att få igång det?
Tänkte koppla ihop den med Tv:n om det går
463 Inlägg
29 april 2010
Du kommer inte kunna köra video till TVn med Bluetooth..
1 854 Inlägg
29 april 2010
Men musik/bilder?
I got Dubs!
2 423 Inlägg
29 april 2010
Check the icon tray (also known as the taskbar) at the bottom of the computer screen. Look for a blue-green square icon with "LAN" in one corner and "B" in the other. Double-click on this icon to open up "Wireless Switch Settings."
Step 2
Open the Vaio Central utility on your computer's operating system if the Wireless Switch icon wasn't in the tray. This can be accessed by the computer's Start menu or by the Vaio Support Central application. Go to the System Information tab in Vaio Central.
Step 3
Open the folder labeled "Network Connections" from the folder list in the System Information tab. Click on the +/- button beside the folder to show the list of options within the folder. Select "Wireless Switch Settings," which should have the blue-green square icon next to it.
Step 4
Check the box in the Wireless Device Switch dialog box that says "Enable Bluetooth Device." This check box is in the middle of the window. Change the wireless LAN from 2.4 GHz to 5 GHz because, as the warning message should say, using the 2.4 GHz wireless LAN and the Bluetooth device can make the connection unstable.
Step 5
Click the "Apply" button after the appropriate boxes are checked. The bluetooth radio is now activated. A blue light should come on near the computer's on/off switch for the Wi-Fi radio.
Step 6
Close the dialog box by clicking "OK." Another box should appear explaining that the Wireless Switch Settings icon should now be in the taskbar. Use this icon if you need to turn off the Bluetooth device and turn it back on later.
