10218
Jag behöver metall
2 Inlägg
21 maj 2010
hej,
finns det en hemsida där jag kan köpa metall? till exempel:
metals4u.
co.
uk/ (förlåt - det finns ett spamfilter)
men bara i sverige. jag vill ha metall för ett projekt. jag behöver den här:
metals4u.
co.
uk/
products.
asp?
cat_id=14
jag vet inte varför  jag kan inte hitta en sida i sverige. en halv timme på google, och ingenting. kanske ser jag på fel ställen?
OBS. min svenska är inte så bra. det ska bli lite lättare om du kan prata engelska, men det är inte ett problem om du kan inte
KHRacing
21 maj 2010
So you need parts of metall right ?
4 example pipes, L-iron. 4-sided pipes, sheets of 1-2-3-4mm etc etc ?
ANY mechanichal workshop vill have this in stock, just go in & ask.
regards /
............Kristian
2 Inlägg
21 maj 2010
im not too sure where i can find them. in örebro, its hard to find anything for DIY projects. youd probably find some basic circuit parts like resistors and switches, but as far as i can tell, there really isnt anything here, and i work in a petrol station with a mechanics shop.
do you have any names of workshops that might be here? i might go to biltema in the next few days to see if they have anything, but im not sure if they will have exactly what im looking for. i need a support structure which can support as much weight as possible, without losing strength, but i cant use an I beam because it twists too much, so i need a channel, or U beam (if you have better suggestions, id like to hear them).
thanks for the help.
KHRacing
21 maj 2010
The only thing Biltema has, are metalsheets like 1000x1000mm nothing else that suits your needs.
but ask in the mechanichal shop @ your work, ask them to forward the adress of any "mekanisk verkstad" to you
7 283 Inlägg
22 maj 2010
http://gulasidorna.eniro.se/hitta:pl%C3%A5t/%C3%B6rebro
There you have alot of people you could call and ask if they sell what you're looking for.
It's really not that kind of business that sells things over the internet here in Sweden.
That's probably why you're having trouble searching for the stuff on google.
10 287 Inlägg
22 maj 2010
Resultat för lokala företag för smidesverkstad nära Örebro
Bista Mekan AB
www.bistamekan.se - 019-21 70 80 - Mer
A E:S Plåt AB
maps.google.se - 019-16 43 60 - Mer
Byggprojekt Olsson & Ström AB
www.byggprojekt.se - 019-500 67 00 - Mer
Örebro Svets & Hydraulik AB
www.orebro.se - 019-32 37 00 - Mer
Lillå Sme'n AB
maps.google.se - 019-31 40 07 - Mer
Smén i Lillån AB
maps.google.se - 019-31 21 86 - Mer
Vintrosa Smed
www.vintrosasmed.com - 070-331 52 99 - Mer
/Göran
(Groucho Marx).
