6143
BMW E30 Street/TimeAttack (DTM style control arms)
-work in progress-
139 072 Visningar
Uppdaterades senast 22 augusti 2018
144 Inlägg
17 mars 2015
Horizontal tube for the seatbelts:
http://i187.photobucket.com/albums/x281/mice325/WP_20150313_19_03_06_Pro__highres_zps7cjkchrs.jpg
IC radiator air duct, didn't have patience to make a mold so I stacked the fiberglass over the foam model:
http://i187.photobucket.com/albums/x281/mice325/WP_20150317_19_59_08_Pro__highres_zps74dmdldo.jpg
Senast redigerat av Mickey_ (17 mars 2015)
144 Inlägg
19 mars 2015
Woohoo, it fits smile
http://i187.photobucket.com/albums/x281/mice325/hengittaa_zps3hi1ekjg.jpg
197 Inlägg
20 mars 2015
#83
Blir snyggt smile . Håppas de uppfyller funktionen  sen smile
144 Inlägg
15 april 2015
Tack, det vi hoppas!
Let's continue after a little break.
Made an inner fender for 650mm tire but it also allows me to use even bigger and wider tire if necessary:
http://i187.photobucket.com/albums/x281/mice325/WP_20150415pieni_zpsbsozbqe7.jpg
Side panel's wheel gap also found it's shape. This 615mm diameter wheel looks a bit tiny with stretched tyre...
http://i187.photobucket.com/albums/x281/mice325/WP_20150414pieni_zpsipo2jncp.jpg
I had to photoshop a picture which demonstrates upcoming wheel setup smile
http://i187.photobucket.com/albums/x281/mice325/testt_zpskgi3mtwz.png
144 Inlägg
22 april 2015
Today's photo smile I'm going to take a fiberglass mold after finishing it with COUPLE of kilos of filler...
http://i187.photobucket.com/albums/x281/mice325/InstagramCapture_13c7a4a9-2da9-4130-8a7c-a7fd5907ba271_zpsz2p6wiip.jpg
619 Inlägg
23 april 2015
#87
Snyggt hantverk big_smile
Tänker du förlänga/flytta baklyktan ut åt sidan eller lämna det som det ser ut nu?
144 Inlägg
23 april 2015
Tack! smile Jag lämna det som det är nu, men jag ska göra nån lufthålen på sidan kanske:
http://stancewords.stanceworks.netdna-c … en-e21.jpg
619 Inlägg
23 april 2015
#89
Gör det med din egen twist så kommer det bli riktigt snyggt. Som du säger kan det ju göras senare också.
Bra jobbat i alla fall smile
144 Inlägg
24 april 2015
Javisst smile
It was a good day to weld some aluminium so I made a fuel surge tank:
http://i187.photobucket.com/albums/x281/mice325/fuelsurgetank_zpskgxfvsvk.jpg
144 Inlägg
30 april 2015
Intercooler water tank, capacity about 10-15liters. Bosch water pump will be located right next to water tank, it pushes water to intercooler then through the radiator back to the tank. Tank still needs divider inside and couple of fittings:
http://i187.photobucket.com/albums/x281/mice325/WP_20150429_22_01_57_Pro__highres_zpsfd01pyxh.jpg
144 Inlägg
9 maj 2015
Alu tanks pretty much completely welded:
http://i187.photobucket.com/albums/x281/mice325/alupontot_zpsdw5je8y9.jpg
Then we move on to something else...
Draw a rectangle:
http://i187.photobucket.com/albums/x281/mice325/reikakonttiinko_zpsokuvlxdl.jpg
..and cut it out. Radiator air outlet:
http://i187.photobucket.com/albums/x281/mice325/reikakontissa_zpsstfnecfg.jpg
Spent few moments measuring M30 head:
http://i187.photobucket.com/albums/x281/mice325/pakolaippamallii_zpsunvh8qls.jpg
Good fit, afterwards I decreased the port size a little bit. I think it's ready for cutting:
http://i187.photobucket.com/albums/x281/mice325/pakolaippasovitus_zpsdfzuwesn.jpg
144 Inlägg
27 maj 2015
Last week I visited at a local paint store and bought 3liters of primer, days are getting warm enough that I can paint the car outdoors.
http://i187.photobucket.com/albums/x281/mice325/WP_20150520_001_zpsvjgcu58e.jpg
Yesterday I tested some kind of special grinding wheel which seemed to remove paint nicely cool
http://i187.photobucket.com/albums/x281/mice325/WP_20150526_18_41_17_Pro_zpsstwh7ujc.jpg
Aaand then I also made an intake flange model, I'll order both IN and EX flanges at the same time:
http://i187.photobucket.com/albums/x281/mice325/WP_20150525_16_32_49_Pro_zpsywll6egr.jpg
Senast redigerat av Mickey_ (27 maj 2015)
144 Inlägg
9 juni 2015
Hmm, it seems that the chassis is getting ready for the primer! Last weekend we cleaned the rest of the chassis (excl. doorposts and the roof). Found just a couple of small rusty spots which I already fixed.
I'll post pictures by the end of the week smile
144 Inlägg
12 juni 2015
The pics I promised, it was a great weather to paint outdoors, sunny, warm and no wind:
http://i187.photobucket.com/albums/x281/mice325/WP_20150612_10_01_51_Rich_zpsnwatfbfz.jpg
http://i187.photobucket.com/albums/x281/mice325/WP_20150612_14_50_16_Rich_zpserxnbbg5.jpg
http://i187.photobucket.com/albums/x281/mice325/WP_20150612_15_45_13_Rich_zpsyo4rbvzz.jpg
http://i187.photobucket.com/albums/x281/mice325/WP_20150612_16_19_40_Pro_zpsv9rltada.jpg
144 Inlägg
22 juni 2015
Just a temporary solution to get the wheel in right place:
http://i187.photobucket.com/albums/x281/mice325/WP_20150617_15_08_52_Pro__highres_zpsvtqzw6ud.jpg
Then I was able to start work the front fenders:
http://i187.photobucket.com/albums/x281/mice325/WP_20150617_16_40_24_Pro__highres_zpsnz4v48eg.jpg
144 Inlägg
27 juni 2015
Front fender has a couple of functions; hot air comes out of the engine bay and wheel well from the back, also air from the front splitter/diffusor will be vented on top of the fender:
http://i187.photobucket.com/albums/x281/mice325/InstagramCapture_6cde791f-4e34-403e-b45c-6f1e5e8ad211_zpsj6cfxiwh.jpg
203 Inlägg
27 juni 2015
#98
Damn! That looks AWSOME! smile
144 Inlägg
12 oktober 2015
No new updates lately, been working with the front fenders just a little bit and designed functional/imo good looking side skirts.. I'll try to get some plywood for the mockup this week.
Custom front control arms have been on pause, prototypes are pretty much ready and I have material and accessories for a couple of sets yikes
I spent few moments with the sketch, this is how things should come out during winter:
http://i187.photobucket.com/albums/x281/mice325/sketch2015_zpsd6ct6gwj.jpg
144 Inlägg
15 oktober 2015
Got the first fully adjustable CrMo control arm prototype "assembled", missing a couple of bushing and a spacer. Complete kit weighs less than half of the orginal setup, but has the same rigidity.
There will be an upcoming contest at our facebook page where you might win one set for free, so make sure to like the page so you won't miss it roll
Control arm pricing will be published by the end of November.
http://i187.photobucket.com/albums/x281/mice325/instacontrolarm_zpstqkj6w2f.jpg
