BMW E30 Street/TimeAttack (DTM style control arms)
-work in progress-
  • 228 Följare
  • 129 952 Visningar
  • Uppdaterades senast 22 augusti 2018
Miuge
25 mars 2016 · 144 Inlägg
Roligt att höra! smile
Exhaust manifold finally welded together, but still needs wastegate piping and coating:
http://i187.photobucket.com/albums/x281/mice325/pakosadsi_zpsi5s6yp18.jpg
BMW 320i "Street-TimeAttack" (1987)
StahlgrenDesign Virtuell Designer
25 mars 2016 · 545 Inlägg
Holy f*cking moley what a project! Ser riktigt bra ut! Följer med spänning! smile
Renault Megane Sport Tourer "Bose Edition" (2017)
Miuge
5 april 2016 · 144 Inlägg
Wastegate arrived quickly, also got few stickers:
http://i187.photobucket.com/albums/x281/mice325/wastegate50_zpsqhsbybc0.jpg
Then I started to make wastegate piping, need to make a mild steel flange though, I don't like to mix it to stainless steel:
http://i187.photobucket.com/albums/x281/mice325/wastegate501_zpsvrrfuned.jpg
Miuge
7 april 2016 · 144 Inlägg
Story continues:
http://i187.photobucket.com/albums/x281/mice325/hukkistatinaillen_zpsvzuf4dt9.jpg
Divided all the way to valve, with sophisticated testing (by blowing air into primaries) the flow seems to find its path well towards the wastegate:
http://i187.photobucket.com/albums/x281/mice325/WP_20160407_20_43_08_Pro__highres_zpsydrcy0ka.jpg
Miuge
16 april 2016 · 144 Inlägg
Recently I've machined and bought some new stuff.
Current engine mounts were kind of temporary, never welded them complete, because turbo and supercharger locations were only approximate.
I wanted a lower design to clear the turbo intake pipe.
The design, steel sleeve with delrin bushing:
http://i187.photobucket.com/albums/x281/mice325/moottorikannake_zps5ih18uqe.jpg
This was something I could machine by myself roll
http://i187.photobucket.com/albums/x281/mice325/moottorikannake2_zpsmxitmuiq.jpg
Obviously I had to mockup alternator location before making intake/charge air piping, but the old one had seen it's best days. Instead of refurbishing and machining new pulleys for the old one I bought a new, smaller, modern alternator:
http://i187.photobucket.com/albums/x281/mice325/laturit_zpsaqtblilc.jpg
This spring and summer will probably be busy time with the project, more parts is already on the way tongue
Miuge
4 maj 2016 · 144 Inlägg
Some new bits acquired, Toyota MR2 electric power steering pump. Remain to be seen if it's even working, connectors had damaged badly during shipping...
http://i187.photobucket.com/albums/x281/mice325/mr2electricpowersteeringpump_zpsutcpdc7b.jpg
Today's job was to make another front fender, it was easy one, I used the same cardboard templates which I made for the driver's side:
http://i187.photobucket.com/albums/x281/mice325/WP_20160504_21_37_27_Pro__highres_zps1i5zpcye.jpg
Extra pic:
http://i187.photobucket.com/albums/x281/mice325/ilta_arska_e30_zpshulrjrz0.jpg
Ricke W
5 maj 2016 · 374 Inlägg
Det ser riktigt bra ut, kämpa på! Kommer du att tävla i Sverige nånting eller blir det bara i Finland?
Ta gärna en titt i min projekttråd!
Ricke Ws Volvo 740 projekt
BMW 528iM (1997)
Miuge
5 maj 2016 · 144 Inlägg
Tackar! Mest i Finland, men jag vill också delta i någon Gatebil event om vi har tid.. cool
Miuge
15 maj 2016 · 144 Inlägg
This will be a frustrating and time-consuming job roll 1 out of 4 corners in progress, after spraying a paint layer I noticed one spot needed to be cut open and hammered down.
http://i187.photobucket.com/albums/x281/mice325/WP_20160511_21_02_57_Rich__highres_zpshsqppjfr.jpg
http://i187.photobucket.com/albums/x281/mice325/WP_20160514_21_18_32_Rich__highres_zpsa57enneo.jpg
Finally got all the parts for the control arms, roll-center/bump steer -adapter fits perfectly cool
http://i187.photobucket.com/albums/x281/mice325/WP_20160512_20_20_45_Rich__highres_zpsgz3olt5b.jpg
Also few lengths of aluminium tubing appeared this week, need to build up something of those
http://i187.photobucket.com/albums/x281/mice325/6tag_110516-111754_zpsc853fp5e.jpg
VictorP
15 maj 2016 · 341 Inlägg
Awesome!
BMW 318 e36 cab "Wannabe m3" (1995)
Miuge
19 maj 2016 · 144 Inlägg
Thanks cool
Earlier this week I bought few liters of paint, should be plenty for mock-ups and molds. I picked the same hue which might be the final color, we'll see...
At this point the fender starts to look like something, but still a lot to do. A couple of bigger dents showed up after the first gray paint layer.
http://i187.photobucket.com/albums/x281/mice325/IMG_7332_zpsxh5hrp5o.jpg
But... this will probably do, picture taken this evening. I'm afraid something goes wrong when I start to mess up with fiberglass big_smile
http://i187.photobucket.com/albums/x281/mice325/IMG_7342_zpsz82mzzru.jpg
I think I should take the camera more often with me, mobile pics look crap besides these..
Miuge
20 maj 2016 · 144 Inlägg
The color, I like cool Paintwork not so perfect but ok for molding
http://i187.photobucket.com/albums/x281/mice325/lokarivari_pieni_zpsxh99mppm.jpg
eastmotorsport -sommar ska de va....
21 maj 2016 · 4 524 Inlägg
Så jäkla läckert!
ripinpeace
21 maj 2016 · 75 Inlägg
följer detta
Ricke W
21 maj 2016 · 374 Inlägg
Hur stor del av karossen kommer du bygga i glasfiber?
BMW 528iM (1997)
OlleOlaglig 2Fast4You
21 maj 2016 · 499 Inlägg
Det kanske är i väldigt tidigt skede att ställa denna fråga men, vad har du tänkt för färg på den när du börjar bli klar?
Hade varit kul att veta så man kan se bilen framför sig i huvudet!
Ford Sierra 2.0T "Wannabe Cosworth" (1988)
Victor_Ahlander
21 maj 2016 · 203 Inlägg
Han skrev ju att den färgen han lackade med nu kan bli den färgen han kommer använda så om du tittar på bilden han la upp så ser du ju vad det är för färg.
Miuge
21 maj 2016 · 144 Inlägg
Precis så Victor smile Och stort tack för alla!
Jag kommer bygga alla skärmar, dörrar, tacklucka, huven osv. i glasfiber så bara inre karosseri och tak är i plåt. Hoppas det väger några kilo mindre. big_smile
madcircle
22 maj 2016 · 261 Inlägg
Fan så sjukt!
Detta måste man följa.  big_smile
Besök gärna mitt Ke70 driftingprojekt
Toyota Corolla DX "Ke70" (1981)
Victor_Ahlander
22 maj 2016 · 203 Inlägg
Det är en jävligt snygg färg kan jag tillägga!
