5474
Baslåda till USB2130
Volvomekaniker
299 Inlägg
30 oktober 2006
Hur många liter ska lådan vara till en USB2130
Diameter  12"
  No. of Coils  2
  Impendance  2x4 Ohm
  Frequency range  <300 Hz
  Power RMS  800 Watt
  Power Max.  2400 Watt
  SPL  85.9 dB
  Max. Voice coul excursion  16.5 mm
  Resonant frequency  29 Hz
  Voice coil resistance  2.9 Ohms/Coil
  Xmax(linear oneway)  0.65"
  Cone Area  -
  Qts  0.334
  Vas  40L
  BI Force Factor  27.656 TM
  Magnet weight  200 Oz
  Manual PDF  N/A
  Specifications PDF  N/A
