Wrc escort Hafsengen Replica Build
My attempt on making a stian hafsengen wrc replica
  • 145 Följare
  • 64 693 Visningar
  • Uppdaterades senast 20 november 2015
cossiedevil22b
2 november 2015 · 78 Inlägg
Bierstube skrev:
cossiedevil22b skrev:
in the uk it would be road legal,but over here its not as easy or testing over here means the car has to be to factory spec in alot of ways ie. car fitted with rear seats need rear seat belts in a rally or caged car this is impossible so wont pass our nct this is why is you watch any Irish ralling all the cars are uk plated for this reaon
Have you considering trying to reg it with UK plates then? If that would be possible regarding to the modifications and regarding to that you live in Ireland - I don't know about these two factors.
Cars is already on a uk plate and if all goes to plan will get registered as a rally car in the paper work and this will then leave me all ok smile
Bierstube
2 november 2015 · 616 Inlägg
Yeah, now when you're mentioning it I remember pictures of your car with those plates. And you're gonna use it for track day events, exhibitions and for road use?
cossiedevil22b
3 november 2015 · 78 Inlägg
slow work starts on getting the shell prep ready for paint due to all the welding and work done to make it close to wrc spec, this means the underside that i have sealed and done twice has to come off as the welding has burnt the sealer off in area's:cry::cry: lots of grinding,and next step then cutting the firewall to weld in the plate needed to run the wrc pedal box cool
http://img.photobucket.com/albums/v246/demonbat/DSCN4024%202.jpg
getting some of the supplies for the sealing of the underside together:icon_smile:
http://img.photobucket.com/albums/v246/demonbat/DSCN4492.jpg
Nearly there:cry:,
http://img.photobucket.com/albums/v246/demonbat/DSCN4029%202.jpg
etch primer:top:
http://img.photobucket.com/albums/v246/demonbat/11401440_10204380098934824_3348997107594714774_n.jpg
Renjaegarn Den som ingen turbo har får åka utan bar
3 november 2015 · 860 Inlägg
Looking good! keep it up!
Administratör för JDM Life Sweden
Toyota Celica GT4 ST205 TTE WRC "Toyota Team Europe Replica" (1996)
Toyota Supra MKIV Turbo "Supraholm" (1997)
Audi A6 Allroad "Lowroad" (2017)
cossiedevil22b
Thanks Mate,its slowly getting there smile
cossiedevil22b
4 november 2015 · 78 Inlägg
some more wrc bits i have from Dewitts uk and MK-motorsport,
http://img.photobucket.com/albums/v246/demonbat/DSCN4747.jpg
http://img.photobucket.com/albums/v246/demonbat/DSCN4357.jpg
http://img.photobucket.com/albums/v246/demonbat/DSCN4361.jpg
I had to make a Pedal box mounting plate, to fit the wrc pedal box
http://img.photobucket.com/albums/v246/demonbat/DSCN4262.jpg
http://img.photobucket.com/albums/v246/demonbat/DSCN4277.jpg
http://img.photobucket.com/albums/v246/demonbat/DSCN4269%202.jpg
Bierstube
4 november 2015 · 616 Inlägg
It would be great if you wanted to show your car when it's finished at Norways biggest show for tuning cars called simply "Oslo Motor Show", a place where at the end of the year (this years show was just finished) Scandinavias best tuning cars are being gathered. Great work as always, by the way!
cossiedevil22b
I wish but it will be nowhere near the quality of the cars there:( but would like to get it gatebil smile,thanks it good be getting to the stage of just bolting everything together
Bierstube
Since you're building it from scratch I suppose the finish will be at a high level when it's done. And also that you're goal is to build a replica as close to Stians car as possible, and he did (as you know) keep a mega high level of the finish of his Cossie. So - I think the odds are quite low for that your car will be close to his when it comes to the finish level at least. Besides of this, guys from Britain are to me known for their great finish level of their Fords and that might be the case for irish people too. smile
Keep up the good work. smile
cossiedevil22b
7 november 2015 · 78 Inlägg
fitted my  X-trac gearbox cradle mounting points made these  and welded them in,
http://img.photobucket.com/albums/v246/demonbat/DSCN4053.jpg
http://img.photobucket.com/albums/v246/demonbat/DSCN4058.jpg
http://img.photobucket.com/albums/v246/demonbat/DSCN4063.jpg
http://img.photobucket.com/albums/v246/demonbat/DSCN4068.jpg
http://img.photobucket.com/albums/v246/demonbat/DSCN4081.jpg
http://img.photobucket.com/albums/v246/demonbat/DSCN4091.jpg
cossiedevil22b
Also started on sealing up my rear turrets and where i had widen the rear arches to suit the wrc wide track setup,i have tried here to get as much of a factory look more so to the standard rough and ready welds left on rally cars,
http://img.photobucket.com/albums/v246/demonbat/DSCN0841.jpg
http://img.photobucket.com/albums/v246/demonbat/DSCN0909.jpg
http://img.photobucket.com/albums/v246/demonbat/DSCN1699.jpg
http://img.photobucket.com/albums/v246/demonbat/DSCN1135.jpg
http://img.photobucket.com/albums/v246/demonbat/DSCN3856_1.jpg
http://img.photobucket.com/albums/v246/demonbat/DSCN3876.jpg
http://img.photobucket.com/albums/v246/demonbat/DSCN3887.jpg
http://img.photobucket.com/albums/v246/demonbat/DSCN4046.jpg
http://img.photobucket.com/albums/v246/demonbat/DSCN4042.jpg
ssmon
7 november 2015 · 80 Inlägg
Great work as always! Always happy when i see you posted another update!
Cortina1
7 november 2015 · 1 026 Inlägg
Ford is the thing. Will be an amazing car
Keep up the good work !
LoFET Almännt tokig
8 november 2015 · 481 Inlägg
Thats a mental buildup man. Loving it !! big_smile
Inline sixes ist sie scheisse.......
JoarH
8 november 2015 · 129 Inlägg
This is just pure awesomeness!!!
cossiedevil22b
13 november 2015 · 78 Inlägg
Thanks Guys
cossiedevil22b
Interior floor and turrets sealed and etch primed,
http://img.photobucket.com/albums/v246/demonbat/DSCN3902.jpg
http://img.photobucket.com/albums/v246/demonbat/DSCN3895.jpg
http://img.photobucket.com/albums/v246/demonbat/DSCN3949.jpg
http://img.photobucket.com/albums/v246/demonbat/DSCN3954.jpg
http://img.photobucket.com/albums/v246/demonbat/DSCN3963.jpg
http://img.photobucket.com/albums/v246/demonbat/DSCN4195.jpg
http://img.photobucket.com/albums/v246/demonbat/DSCN4219.jpg
cossiedevil22b
Made clamps to hold the rad in and also made brackets to bolt the fan housing down to the radiator aswell dont mind the fan as these are not what is going to used,
http://img.photobucket.com/albums/v246/demonbat/DSCN4458.jpg
cossiedevil22b
pedal box fitment finished from start to end,
http://img.photobucket.com/albums/v246/demonbat/DSCN4762.jpg
http://img.photobucket.com/albums/v246/demonbat/DSCN4766.jpg
http://img.photobucket.com/albums/v246/demonbat/DSCN4768.jpg
http://img.photobucket.com/albums/v246/demonbat/es2.jpg
http://img.photobucket.com/albums/v246/demonbat/es3.jpg
http://img.photobucket.com/albums/v246/demonbat/es5.jpg
http://img.photobucket.com/albums/v246/demonbat/es4.jpg
cossiedevil22b
14 november 2015 · 78 Inlägg
finished off the passenger side foot rest as needed to cover over the radiator pipes,and i have to make the same for the driver side,
http://img.photobucket.com/albums/v246/demonbat/DSCN4411.jpg
http://img.photobucket.com/albums/v246/demonbat/DSCN4412.jpg
http://img.photobucket.com/albums/v246/demonbat/DSCN4413.jpg
http://img.photobucket.com/albums/v246/demonbat/DSCN4425.jpg
http://img.photobucket.com/albums/v246/demonbat/DSCN4431.jpg
driver and passenger alloy foot rest plates made,
http://img.photobucket.com/albums/v246/demonbat/DSCN4829.jpg
http://img.photobucket.com/albums/v246/demonbat/DSCN4825.jpg
http://img.photobucket.com/albums/v246/demonbat/DSCN4842.jpg
http://img.photobucket.com/albums/v246/demonbat/DSCN4836.jpg
http://img.photobucket.com/albums/v246/demonbat/DSCN4850.jpg
http://img.photobucket.com/albums/v246/demonbat/DSCN4858.jpg
http://img.photobucket.com/albums/v246/demonbat/DSCN4880.jpg
