6170
Nissan 200sx s13 "Dirtbag" (ca18det) just nu Motor! trim/renovering
303 Inlägg
12 april 2011
nu är de dags att bygga om henne=) kommer vara ett långtidsprojekt men en del har redan hänt!https://www1.garaget.org/gallery/images/94/93351/93351-1cb7bc9662e84e9e290d532cd88ecacc.jpghttps://www1.garaget.org/gallery/images/94/93351/93351-324001c0219a81a5df89746cc7295e88.jpg
https://www1.garaget.org/gallery/images/94/93351/93351-bb22fd8f5da12808770dd83b0ffeb08f.jpg
https://www1.garaget.org/gallery/images/94/93351/93351-2ac09831296ad09d48d866987249a32e.jpg
halvstrippad
https://www1.garaget.org/gallery/images/94/93351/93351-0b82f5524a18ecd28d9cb1cb94ccc3a6.jpghttps://www1.garaget.org/gallery/images/94/93351/93351-aad400404727df662cfc93c9e547c5e9.jpg
kolvarna ur
https://www1.garaget.org/gallery/images/94/93351/93351-c49e4b6615aa2cbec61aeafa5ef70a68.jpg
så var blocket rent! smile
https://www1.garaget.org/gallery/images/94/93351/93351-6602e17db98a84f9a56b595db8042cb7.jpg
https://www1.garaget.org/gallery/images/94/93351/93351-5e41a178a950f622d1267dbc6802e6b3.jpg
lite svart motorfärg!
https://www1.garaget.org/gallery/images/94/93351/93351-512addb56caae7101319589507675a23.jpg
toppen ska planas å veven poleras hos motorrenoverarn!
https://www1.garaget.org/gallery/images/94/93351/93351-c483dd5204044c12bff4752e371831c2.jpg
https://www1.garaget.org/gallery/images/94/93351/93351-4f49b846a57412e6e6b35f406c1553da.jpg
kolvarna jag köpt=) 1 mm större än original så ska borra blocket senare!
https://www1.garaget.org/gallery/images/94/93351/93351-9b0cb48bbf765b70f5f4de71e307cfd7.jpg
lite mer godis!
https://www1.garaget.org/gallery/images/94/93351/93351-49a14f40ec134d1d41b2e5e31b93242d.jpg
blocket borrat å planat
https://www1.garaget.org/gallery/images/94/93351/93351-a8695f7c82e6fe6390488baaea067d3e.jpg
nya ramlager. dom gamla var riktigt illa däran:O
https://www1.garaget.org/gallery/images/94/93351/93351-f69fb1e99ae6d10517df1abd00ea621a.jpg
går sakta framåt!smile
https://www1.garaget.org/gallery/images/94/93351/93351-0c30ed1c4b779aeebb6b02d327a42035.jpg
så var wössner kolvarna i oxå.
https://www1.garaget.org/gallery/images/94/93351/93351-8d2d6e94834575596679979a70567fa7.jpg
ny topppackning å ARP bultar
https://www1.garaget.org/gallery/images/94/93351/93351-716635122d46e6e9904604769a896f59.jpg
toppen på å momentdragen samt oljetråg och ny oljepump.
https://www1.garaget.org/gallery/images/94/93351/93351-a6ebe75f80ac92a24107e216b5dda80c.jpg
https://www1.garaget.org/gallery/images/94/93351/93351-3f74590ffeb1b3c9158d33174e16acd8.jpg
idag fick jag även dit servopump generator å lite mer smått å gott!
Har en fråga ang lyftarna. tänkte lufta dom och är de nåt mer jag ska tänka på nä jag ska sätta dit dom igen? ka de va inoljade?
tacksam för svar!
Senast redigerat av _blitz_ (12 april 2011)
303 Inlägg
12 april 2011
Ingen som vill titta när jag tar mej tiden att göra en projekttråd? sad kanske e för många s13 projekt hehe
2 117 Inlägg
12 april 2011
Jag kollar gärna. Det är alltid kul med en projekttråd som din smile
2 117 Inlägg
12 april 2011
tacksam för svar!
Olja in dem ordentligt även på utsidan när du sätter tillbaka dem. De ska helst sitta på samma plats de satt på innan du tog bort dem.
303 Inlägg
12 april 2011
här klagar man så får man inlägg av självaste shogun big_smile inte fyskam!
ok tack för hjälpen med de då blir de garaget imorn kväll!
jusste kan man använda redline's assembly lube till kamaxlarna med? eller måste de vara kamaxelfett?
(använde redline när jag plockade ihop motorn)
303 Inlägg
12 april 2011
bjuder på en liten rökare smile
den sista innan bilen togs in i garaget!
http://www.youtube.com/watch?v=xntb2OkUfgA
Jlmmy
12 april 2011
Ser ju trevligt ut! smile
Lycka till nu med allt
653 Inlägg
12 april 2011
Å tusan nån som fått sina wössner kolvar levererade i rätt dimension smile
Ser ut som ett trevligt projekt!
303 Inlägg
12 april 2011
hehe rätt å rätt dom är ju 1 mm större än original så de har borrats;) men de gör inte mej nåt!big_smile
tack så mkt smile
303 Inlägg
13 april 2011
blev inte nå meck idag:( var iaf å hämtade lite grejer som ligger i diskmaskinen just nu hehe! hoppas på fint resultat:D
Hjultomte
1 500 Inlägg
13 april 2011
Jädra fint det kommer bli big_smile Bilen såg faktiskt bra ut också så hoppas att du får många mil på vägen med den tongue
Min bil går inte för sakta. Bara inte snabbt nog!!!
303 Inlägg
13 april 2011
tack så mkt! ja det hoppas jag med! smile
303 Inlägg
13 april 2011
körde i diskmaskin tidigare men blev inte så mkt renare så skrubbade nån timme med svinto.
blev lite bättre men inte 100% men men ja e nöjd iaf=) de får va bra nu!
https://www1.garaget.org/gallery/images/94/93351/93351-ab7fdb90328e8b759ed07a613e814232.jpg
https://www1.garaget.org/gallery/images/94/93351/93351-0c9ade2b25c7cc8152c7401a63660958.jpg
2 117 Inlägg
13 april 2011
Det går men kamfett är bättre eftersom det stannar kvar längre tills oljetrycket har kommit upp och oljan börjar skapa oljefilm. Innan dess måste metallkontakt förhindras.
303 Inlägg
13 april 2011
ok men då e de bäst att införskaffa lite kamfett=)
tack för svar!
368 Inlägg
13 april 2011
trevligt motorbygge du har där, ser ut att bli bra big_smile
303 Inlägg
14 april 2011
tack så mkt:)
idag har de hänt litegrann iaf:)
https://www1.garaget.org/gallery/images/94/93351/93351-a1f4c0fb050e6cfc8710cf05ed3198e0.jpg
i full gång med att slipa ventilkåpor
https://www1.garaget.org/gallery/images/94/93351/93351-f0a761b9f4a50c61979c059b61697a9a.jpg
första lagret lack på. har grundat 3 varv oxå men glömde fota de;P
https://www1.garaget.org/gallery/images/94/93351/93351-35dbe97b1721b967c04d4e790792d694.jpg
2:a lagret. ska klarlacka imorn så är sugen på att se resultatet, å vad tycks om färgvalet?
sen satte jag i lyftarna å kammarna med när färgen torkade:)
https://www1.garaget.org/gallery/images/94/93351/93351-85d521386163ac5a7966b556b19e0dc5.jpg
https://www1.garaget.org/gallery/images/94/93351/93351-7cc334d7249051cdde81a7911a863de4.jpg
de var dagens goda gärning, imorn blir de mer=) gonatt!
303 Inlägg
15 april 2011
här kommer en update från dagens jobb.
klarlackade ventilkåporna. blev rätt bra tycker jag:D
https://www1.garaget.org/gallery/images/94/93351/93351-0d428e0238a6e4eef7d2463d246b562d.jpg
fick på plåten bakom kamdreven å dreven då, sen lite mer plock
https://www1.garaget.org/gallery/images/94/93351/93351-2a84e1c4d17b57d3b32f0eb4921066f2.jpg
passade även på att slipa frontkåpan sen grunda den.
sen har man ju svårt att slita sej från garaget när man e där så polerade cas:en med:P
kommer bli snyggt tror jag när jag lackat frontkåpan svart oxå eller?
https://www1.garaget.org/gallery/images/94/93351/93351-cadad908973bdd292464af6850a57d72.jpg
sen upptäckte jag till min förskräckelse när jag städade iordning osv att de e ju snuskigt mkt grejer kvar hehe
hur fan ska man få tillbax alla smådelar?tongue kommer inte ihåg var hälften av alla småslangar å diverse plåtar satt men de kanske löser sej!
får iaf plats med grejerna på ett bord nu, när jag började var de 2 fulla bord:)
här e en bild på resterande delar
https://www1.garaget.org/gallery/images/94/93351/93351-3e64d21761f6fb79a76bba115efc3779.jpg
hittade äntligen en i stan som kan ta hem reservdelar till 200sx nu så har beställt halvmånarna (gummipacningarna mot torpedväggen på toppen), skruvarna till vattenpump och lite mer skruvar å dyl.
de var dagens arbete!
kommentera gärna! smile
Senast redigerat av _blitz_ (15 april 2011)
303 Inlägg
15 april 2011
skulle böehöva hjälp med en sak!
någon som har lust att ta kort på sitt insug på sin ca18det runt om så jag ser hur allting ska sitta?
vore trooooooligt snällt!
mvh Johan
653 Inlägg
16 april 2011
tack så mkt smile
Syftade mest på att jag fick fel dimension på kolvarna först när jag beställde smile dock superbra support, de stog för frakten att skicka tillbaka dem så skickade de nya!
