Evighetsprojektet..... -Renovering och överladdning av BMW 325ix-89
Rullande renovering och trimning av en väldigt nergången bil.
  • 16 Följare
  • 21 003 Visningar
  • Uppdaterades senast 14 januari 2016
Antimin Jack of all trades
12 augusti 2012 · 41 Inlägg
Mer bilder....
https://www1.garaget.org/gallery/images/97/96341/96341-1af35e74299621bcc45a4378e692ac13_tn.jpg https://www1.garaget.org/gallery/images/97/96341/96341-e5a2fdbbdd2b126df7cae17b5bdb24c3_tn.jpg https://www1.garaget.org/gallery/images/97/96341/96341-50145f47f82a28aee66849614fcee4a3_tn.jpg https://www1.garaget.org/gallery/images/97/96341/96341-bec5177ebd3d7b49d6d33dcf478d585e_tn.jpg https://www1.garaget.org/gallery/images/97/96341/96341-21d0b3f7cee592098fe942b087463bc5_tn.jpg https://www1.garaget.org/gallery/images/97/96341/96341-299edd4331680fd965cab8a833c6aceb_tn.jpg https://www1.garaget.org/gallery/images/97/96341/96341-3d32ae97152991ada85d20ae978a21c0_tn.jpg https://www1.garaget.org/gallery/images/97/96341/96341-c9fbb7df4e12bfbda5ffc25042dbc3b9_tn.jpg https://www1.garaget.org/gallery/images/97/96341/96341-cff49c664d09212f0869914d1ba46572_tn.jpg https://www1.garaget.org/gallery/images/97/96341/96341-be7b0574c461d4319bcb7670e5a9f169_tn.jpg https://www1.garaget.org/gallery/images/97/96341/96341-2f3a2a91ef192e5645d7eda481e01fed_tn.jpg https://www1.garaget.org/gallery/images/97/96341/96341-f1c719bfe24faf93a29b92f242f95a9f_tn.jpg https://www1.garaget.org/gallery/images/97/96341/96341-8a9ce3ad5549d4115a64bffe34c1ff2e_tn.jpg https://www1.garaget.org/gallery/images/97/96341/96341-0b6d5ca359f78e9ec1986e12809fa75d_tn.jpg https://www1.garaget.org/gallery/images/97/96341/96341-68a76fb6cce30b5a4f2605e66bed4c3b_tn.jpg https://www1.garaget.org/gallery/images/97/96341/96341-5cf8e6310cc1fa658c1bc2db5aaf829a_tn.jpg https://www1.garaget.org/gallery/images/97/96341/96341-b91605adefa68c3925dcc62bbeb69651_tn.jpg
The only cure for bad handling is more power
BMW 325ix touring "Prowler" (1989)
19 augusti 2012 · 41 Inlägg
Detta är gjort på eller till bilen det senaste året:
Samtliga bakre bromsrör samt soppaledningar bytta.
Ny vattenpump.
Ny kamrem + spännare.
Renoverad servopump.
Stötdämparna bytta till bättre beg.
Främre bromsskivor bytta och oken renoverade.
Instrumenthuset bytt.
Oljefilteradapter och oljetrycksmätare monterade.
Diverse kylslangar bytta.
Kupefläkten bytt.
Bränsletanken bytt.
Bakdiffen renoverad med nya lager och packningar samt pulverlackad svart, dock inte monterad i skrivande stund.
Nytt batteri.
Subframe: blästrad och pulverlackad, ej monterad ännu.
Främre länkarmar: blästrade, pulverlackade och nya polyurethanebussningar inhandlade. Väntar på spindlar.
Bakre länkarmsbrygga: blästrad, pulverlackad, nya polybussningar och ombyggd så camber och toe kan ställas. (ej monterad)
Bakre länkarmarna: blästrade, pulverlackade med nya polybussningar, hjullager, bromssköldar, handbromsbackar och vajerlänkage. (ej monterade)
Främre och bakre krängningshämmare: Blästrade, pulverlackade och nya stag+polybussningar. (ej monterade)
Nya styrleder.
Bakre bromsok renoverade. (ej monterade)
Topplock förberett för svetsning. (väntar på att få en stödplatta utskuren)
Rostlagning och preppning för lack. (pågående)
Nya framskärmar. -pulverlackade så klart.
Motorsköljning.
Samtliga vätskor bytta utom vxlådan... (Får inte bort påfyllningspluggen)
Hur mycket tid och pengar som hittils är nerlagt på den har jag inte riktigt vågat räkna på ännu.. Det tråkiga är att pengarna inte räcker til ändål just nu, så allt utom besiktning, rostlagning och lackering får snällt vänta.
Här är lite av det jag har kvar att skaffa.
Inre och yttre spindlar. 2400kr
Främre hjullager. 1200kr
NYA dämpare. 5000kr
Ny kylare. 1200kr
255l/min soppapump. 500kr
Div lister och massor av monteringsclips. 500kr
Andra framstolar. 2500kr
Nya lyktor. (angeleyes+xenon) 3000kr
mm. mm. mm.
Senast redigerat av Antimin (19 augusti 2012)
25 augusti 2012 · 41 Inlägg
https://www1.garaget.org/gallery/images/97/96341/96341-28fc9329bfd401a18de7c6448e9de974.jpg
Bakgaveln på plats. Det kommer bli ett väldans pusslande på vänstersidan.
9 september 2012 · 41 Inlägg
Jag hade hoppats att kunna besikta den 28e sep och köra till BMCs avslutningsträff den 29e men det kan jag nog glömma..
22 september 2012 · 41 Inlägg
Äntligen!!!!
Den rosten som skulle fixas innan lack är fixad. En del kvarstår men det får jag ta tag i senare.
Nu ska jag ner till garaget och lacka bagagerummet invändigt.
12 oktober 2012 · 41 Inlägg
Då jag lyckats bli rejält förkyld så har det inte hänt så mycket med bilen dom senaste dagarna. Den har blivit färdigspacklad, slipad och grundad. Nu har jag dock blivit så pass kry igen att jag kan ta tag i sista slipningen och äntligen få lack och klarlack på den.
https://www1.garaget.org/gallery/images/97/96341/96341-4efede780e080134eb693d165e0356df_tn.jpg https://www1.garaget.org/gallery/images/97/96341/96341-0e5b04cb34df840a8fc71fb23d8e4e66_tn.jpg https://www1.garaget.org/gallery/images/97/96341/96341-c577b09c648eae3915dfff3f8c3d74af_tn.jpg
Senast redigerat av Antimin (12 oktober 2012)
21 oktober 2012 · 41 Inlägg
Lacken lagd. Resultatet över förväntan. Ändå åker jag nog på att lacka om huven och vänster bakskärm för att jag ska bli riktigt supernöjd.
https://www1.garaget.org/gallery/images/97/96341/96341-d6bd19a2218a3b292515ab42ad8fe017_tn.jpg https://www1.garaget.org/gallery/images/97/96341/96341-bd4c48c59df093193d70e1dfdae68a08_tn.jpg https://www1.garaget.org/gallery/images/97/96341/96341-302dd36cf4b1ab3771bb8dcc1b990aa3_tn.jpg https://www1.garaget.org/gallery/images/97/96341/96341-642f404bf1c25d4898e1d2941df67f53_tn.jpg https://www1.garaget.org/gallery/images/97/96341/96341-4c5d3383e3537b5190eb29cb9eea93d9_tn.jpg https://www1.garaget.org/gallery/images/97/96341/96341-ed58484858e3930120e22c9ee1fd8d87_tn.jpg
Senast redigerat av Antimin (21 oktober 2012)
25 oktober 2012 · 41 Inlägg
Man ska inte backa ut ur garaget med bakluckan uppe, man ska in te backa ut ur garaget med bakluckan uppe, man ska in te backa ut ur garaget med bakluckan uppe, man ska in te backa ut ur garaget med bakluckan uppe, man ska in te backa ut ur garaget med bakluckan uppe, man ska in te backa ut ur garaget med bakluckan uppe, man ska in te backa ut ur garaget med bakluckan uppe, man ska in te backa ut ur garaget med bakluckan uppe..... Japp.... Ny lucka måste inhandlas..'
28 oktober 2012 · 41 Inlägg
Gamla rostiga bakluckan på plats... Ny lucka är beställd och ska hämtas på fredag.
Fälgarna lackade.
https://www1.garaget.org/gallery/images/97/96341/96341-9210fa4b50ee2733fbd9329583a586fc.jpg
Fälgarna lackade
2 november 2012 · 41 Inlägg
https://www1.garaget.org/gallery/images/97/96341/96341-3ca76b58ef2e04c868790becc9e04782.jpg
17" provmonterade...
Wooooooohooooooo! ÄNTLIGEN har alla lager och lagerbanor till bakdiffen kommit. Så fort jag har schimsat in allt och monterat ihop den ska jag byta ut subframen, länkarmarna, diffen och krängningshämmaren mot allt jag har renoverat.
8 november 2012 · 41 Inlägg
https://www1.garaget.org/gallery/images/97/96341/96341-59b1183b91d7e2a60f6b37a130b6d3d9.jpg
som sagt....
Hämtade den "nya" luckan i fredags och det visade sig tyvärr att den var bra rutten under rutan.. Inte lätt för varken säljaren eller mig att se..
26 november 2012 · 41 Inlägg
Det har hänt en hel del sedan jag uppdaterade sist.. Alla lister har lackats, den krökta  bakluckan har blivit tillfälligt utbytt mot den rostiga men inte riktigt lika krokiga luckan som satt på från början. Nu är allt monterat och grovjusterat... Massvis med arbete kvar... Kan kalla det för beta stadiet..
Såååå...Vad tycks?
https://www1.garaget.org/gallery/images/97/96341/96341-54d4362ff9f4904722c9e8e11cab3020_tn.jpg https://www1.garaget.org/gallery/images/97/96341/96341-c12a0131cf7d7fe51cb30d438c5c1c05_tn.jpg https://www1.garaget.org/gallery/images/97/96341/96341-0b5c0dbb3ea553b1c99eaa5ab932a79b_tn.jpg https://www1.garaget.org/gallery/images/97/96341/96341-3a199e5bc805f8807985120a55bf0211_tn.jpg https://www1.garaget.org/gallery/images/97/96341/96341-fb823f84bf0edf6d6c70612a95c13c20_tn.jpg https://www1.garaget.org/gallery/images/97/96341/96341-d39edadf4c73dfa907d93bd11191c06f_tn.jpg https://www1.garaget.org/gallery/images/97/96341/96341-a355886fd60226051077f9e80c3b7918_tn.jpg
22 februari 2013 · 41 Inlägg
Projektet ligger fortfarande på is... Återupptas efter maj då jag har ekonomi till det.
1 april 2013 · 41 Inlägg
Lite har blivit gjort dom sista dagarna. Jag har renoverat bakdiffen och förmonterat länkarmarna i bakvagnsbryggan.
Lite bilder.. https://www1.garaget.org/gallery/images/97/96341/96341-96734b383b322061888759d1615becab_tn.jpg https://www1.garaget.org/gallery/images/97/96341/96341-15744fafbb81d93ff41fdd6b52a97f18_tn.jpg https://www1.garaget.org/gallery/images/97/96341/96341-9c9e4763fa1ab20e4e16d67c8281653d_tn.jpg
15 april 2013 · 41 Inlägg
Den 11e maj ska den nya bakvagnen lyftas på plats.
joxxan
15 april 2013 · 334 Inlägg
Gött! big_smile
Just... Awsome!
11 maj 2013 · 41 Inlägg
18 timmar in i bakvagnsbygget. Allt har strulat som vanligt och naturligtvis hittar man mer rost än planerat. Lägger upp några före bilder på bakvagnen. Efter bilderna kommer inom kort.
https://www1.garaget.org/gallery/images/97/96341/96341-844b3758e398e9e24890754ceb3e6dc4_tn.jpg https://www1.garaget.org/gallery/images/97/96341/96341-bcfd8cf308fe033543d29f4466b84118_tn.jpg https://www1.garaget.org/gallery/images/97/96341/96341-96c6aa8c2628ed743552661ffaa6334c_tn.jpg https://www1.garaget.org/gallery/images/97/96341/96341-b6fe02471b3c81aaaaa81b9ec2f36ed0_tn.jpg https://www1.garaget.org/gallery/images/97/96341/96341-3a1f4b2546b923e035168ba8525b5417_tn.jpg https://www1.garaget.org/gallery/images/97/96341/96341-edf117afa559538f2692775dc2550858_tn.jpg https://www1.garaget.org/gallery/images/97/96341/96341-d95abded49573f48c7d0c1c55748a406_tn.jpg https://www1.garaget.org/gallery/images/97/96341/96341-2c330fbec91db5f718dd400ea34f9491_tn.jpg https://www1.garaget.org/gallery/images/97/96341/96341-738f7f78e8ae4bbe994f3985e4e77b47_tn.jpg https://www1.garaget.org/gallery/images/97/96341/96341-0a5c72ffb1e37f4b42ffcd84229a974a_tn.jpg
loudness
11 maj 2013 · 4 554 Inlägg
härlig renovering du ger dig in på. mycke intressanta moment du gör som kommer bli aktuellt för mig när tiden kommer... såg att din diff läckte på samma ställa som min, kanske vanligt:P rev ner min i förrgår för att byta packboxar. ska bli kul å följa detta!
Tackar, tackar... Jo, ibland undrar man lite vad man håller på med.
