13688
BMW E30 Street/TimeAttack (DTM style control arms)
-work in progress-
144 052 Visningar
Uppdaterades senast 22 augusti 2018
144 Inlägg
9 februari 2017
One more picture of the finished prototype with trigger wheel added:
http://i187.photobucket.com/albums/x281/mice325/atiprint_zps2yya33ie.jpg
I was thinking to spend this weekend strictly at the garage, today I continued some aluminum welding and I'll probably post more updates in the end of week..
144 Inlägg
13 februari 2017
Clutch setup arrived, probably not going to use twin mass flywheel roll
http://i187.photobucket.com/albums/x281/mice325/clutch_setup_zpslwbisric.jpg
Now that I also got silicone hoses I continued welding, first mounted a throttle body:
http://i187.photobucket.com/albums/x281/mice325/cold_side_zpsr6gqiumx.jpg
Then the other side, that's the only place where I was able to mount blow off valve:
http://i187.photobucket.com/albums/x281/mice325/moar_aluminum_zpslkk2ye8s.jpg
Some coolant pipes and new mounts for the power steering pump:
http://i187.photobucket.com/albums/x281/mice325/moar_aluminum2_zps80vdoqud.jpg
144 Inlägg
14 mars 2017
I had some struggle machining the oil pump back plate manually, I did two versions which didn't turn out too good. I also tried a shortcut welding a sleeve into the orginal cast cover.. Because of the high Mg content welds won't hold even if they would look good, here's the result of light hammering, crispy:
http://i187.photobucket.com/albums/x281/mice325/16819529_785183408296082_686091811070864522_o_zpsclz8gqsd.jpg
It was time to start over, I did some changes to model and discarded the idea of a water jet cut blank because of it's ridiculous price. I happened to find a company which would machine the part for me very cheap with their 5-axis machine. I just confirmed it fits by 3D printing a mockup:
http://i187.photobucket.com/albums/x281/mice325/m30oilpumpcover_zpsyoda8qr4.jpg
The final part (made of AW-7075) should arrive in three weeks smile
144 Inlägg
19 mars 2017
...Not again neutral
http://i187.photobucket.com/albums/x281/mice325/WP_20170318_18_03_24_Rich__highres_zpsilk7fo6h.jpgReason? I managed to change the engine position after modifying steering rack mounts, so when I renewed engine mounts I positioned it as low as possible and even further back. Besides the welds looked terrible now that I've learned to TIG somehow roll Upcoming version will be looking quite different.
Now that I got the taste of cutting I cut the comp housing outlet too:
http://i187.photobucket.com/albums/x281/mice325/WP_20170318_20_36_04_Rich_zpss0dxrcek.jpg
To change it to this:
http://i187.photobucket.com/albums/x281/mice325/WP_20170318_21_09_13_Rich__highres_zpsjd2fyv79.jpg
Few Finnish fellows were inquiring M20/M30 cam sensor covers from us as we had made some 3D printed prototypes earlier (in co-operation with Juuso's Garage), these anodized aluminum versions are about to arrive soon:
http://i187.photobucket.com/albums/x281/mice325/cam_sensor_cover_MRT_zpsisgqox90.jpg
144 Inlägg
25 mars 2017
Oil pan project:
http://i187.photobucket.com/albums/x281/mice325/WP_20170321_21_08_41_Rich__highres_zps677cratu.jpg
Front sump is only to clear oil pump:
http://i187.photobucket.com/albums/x281/mice325/WP_20170322_22_23_51_Rich__highres_zpsa4hlkmqb.jpg
Long welds:
http://i187.photobucket.com/albums/x281/mice325/WP_20170323_20_30_26_Rich__highres_zpsolrx5wan.jpg
Oil pan baffle with trapdoors, screws are only temporary, those will be replaced with rivets:
http://i187.photobucket.com/albums/x281/mice325/WP_20170324_19_26_36_Rich__highres_zps8kh9mgoj.jpg
Assembly taking shape:
http://i187.photobucket.com/albums/x281/mice325/WP_20170324_19_54_55_Rich__highres_zpsdg9x7eel.jpg
144 Inlägg
1 april 2017
Stainless steel oil intake screen, not yet welded, custom made of course:
http://i187.photobucket.com/albums/x281/mice325/intakescreen_zpstou0gd5i.jpg
Aluminum fuel rail, not yet anodized, custom made of course:
http://i187.photobucket.com/albums/x281/mice325/WP_20170331_19_07_18_Rich__highres_zpshd1bavgm.jpg
79 Inlägg
2 april 2017
#187
This is amazing, very motivating to see! Keep up the good work!
144 Inlägg
6 april 2017
Thank you! It's also motivating to see someone posting a comment here big_smile
This week I started and finished making a coolant reservoir and oil catch can with crankcase + cylinder head ventilation:
http://i187.photobucket.com/albums/x281/mice325/cancans_zps6kadlhhf.jpg
144 Inlägg
10 april 2017
One more aluminum tank.. Fuel surge tank that has been in progress for a loong time. It needed a baffle inside, end cap and AN fittings for fuel in and out, unfortunately AN6 fittings were out of stock at the local store so I wasn't able to completely finish it mad Underneath my FPR with AN10 in/outlets:
http://i187.photobucket.com/albums/x281/mice325/surgetank_regulator_zps4fbglsw3.jpg
Finally got this part I've been waiting for, shiny aluminum bit from Italy:
http://i187.photobucket.com/albums/x281/mice325/oilpumpbackplate_zpsjwimhrrq.jpg
144 Inlägg
10 maj 2017
Okay where were we..
Oil pan bolted to the engine and it still fits, couple of small additions need to be done before I can say it's complete. Oil stick will be attached with AN fitting, as easy as it gets:
http://i187.photobucket.com/albums/x281/mice325/18222359_830360037111752_7907193932586596436_n_zpsqjyqilwl.jpg
I ordered a batch of AN12 fittings and hose for IC water lines and oil breather lines (yeah I already welded stupid hose fittings in the breather can so I need to change them):
http://i187.photobucket.com/albums/x281/mice325/18358579_833280026819753_3071619997930481381_o_zpsw5znhmrw.jpg
Had to push the car out while cleaning the garage, notice my nice new wheels:
http://i187.photobucket.com/albums/x281/mice325/18320580_830975220383567_3144969774216780619_o_zpsu1rssh7t.jpg
144 Inlägg
29 maj 2017
Some pictures before I cleaned the garage, the reason why I have now worked with the car outdoors:
http://i187.photobucket.com/albums/x281/mice325/IMG_20170510_210227_zpsgwmp6rni.jpg
http://i187.photobucket.com/albums/x281/mice325/IMG_20170512_234112_zpss1kgnnnx.jpg
Today the driver side rear quarter looked like this, soon getting ready for molding. Front fenders are almost done too, some minor spots that I'm not happy with, but after all it's going to be a race car, so... roll
http://i187.photobucket.com/albums/x281/mice325/IMG_20170529_194348_zpshbylruiu.jpg
http://i187.photobucket.com/albums/x281/mice325/18700216_843686059112483_1526725375541171792_n_zpsvn4vxe8s.jpg
Batch of these were sold out quite quickly, so if any of you M20/M30 builders are interested send me a PM or contact via facebook, new batch is coming.
http://i187.photobucket.com/albums/x281/mice325/black_zpsd0tr2p9s.jpg
http://i187.photobucket.com/albums/x281/mice325/silver_zpssr6cqpgj.jpg
http://i187.photobucket.com/albums/x281/mice325/trig_zpsmkqpnb3x.jpg
Senast redigerat av Miuge (29 maj 2017)
144 Inlägg
18 juni 2017
Bodywork fabrication continues, driver's side is already quite good. I remade the side skirt model which is much simpler, lighter and should work better. I'll take a picture for the next post.
Before I cut the hood I made a tunnel for the radiator, all the air goes in front bumper and then exits the hood vent, should be effective enough.
http://i187.photobucket.com/albums/x281/mice325/44b56388-c689-4c33-9c24-eaa98e9b7835_zpsmdmqi4nu.jpg
http://i187.photobucket.com/albums/x281/mice325/hoodvent3_zpsphzeruaw.jpg
http://i187.photobucket.com/albums/x281/mice325/hoodvent2_zpsxt9sging.jpg
I tried to remain some orginal body shapes yet not forgetting functionality.
374 Inlägg
20 juni 2017
#193
Looking awesome, as always!
Ta gärna en titt i min projekttråd!
Ricke Ws Volvo 740 projekt
144 Inlägg
22 juni 2017
Thanks Ricke!
I spent few days with the hood before our holidays, to be continued next week. To perceive the next part of the puzzle I already cut the front bumper in pieces smile
http://i187.photobucket.com/albums/x281/mice325/IMG-20170621-WA0003_zpsorcfbnk6.jpeg
619 Inlägg
22 juni 2017
#195
That's going to look awesome!
Are you planning on keeping the vents as they are now or will you be putting some sort of grid over?
Not sure which will look better or if there is a gain with either.
144 Inlägg
22 juni 2017
Thanks Gussam!
I'm not quite sure yet, but I might add a simple flap or two in the middle of the vents to guide air and give it some looks..
http://image.superstreetonline.com/f/fe … d_vent.jpg
144 Inlägg
18 juli 2017
Soon it's time for updates.. Tomorrow I should be able to lay some fiberglass to front bumper, currently it's riveted together with sheet metal pieces. Spending my holidays from work so I've got time to make some progress hopefully smile
I got some interesting parts in my hands lately, makes me rethink my front setup roll
http://i187.photobucket.com/albums/x281/mice325/both_zpsbegpzoi9.jpg
http://i187.photobucket.com/albums/x281/mice325/IMG_20170719_002330_zpswxmxhesz.jpg
144 Inlägg
20 juli 2017
So... the front bumper. This is how it looked with sheet metal "mold", quickly threw together for next step:
http://i187.photobucket.com/albums/x281/mice325/IMG_20170719_181340_zpshgppmpjb.jpg
Some fiberglass laid behind, total 4-5 layer was used to get enough stiffness:
http://i187.photobucket.com/albums/x281/mice325/IMG_20170719_200449_zpslpinogwh.jpg
Took off the sheet metal parts and this is the result, next some filler..
http://i187.photobucket.com/albums/x281/mice325/IMG_20170720_193828_zpsfrke8vw9.jpg
-sommar ska de va....
4 545 Inlägg
21 juli 2017
#199
Ser väldigt bra ut!
144 Inlägg
25 juli 2017
Tack eastmotorsport!
Getting there, now it has more solid look smile
http://i187.photobucket.com/albums/x281/mice325/IMG_20170725_211718_182_zpstu1miewj.jpg
