To reset the service reminder on a 2014 Subaru Outback 2.0D, you'll need to access the maintenance settings through the vehicle's information display.
Use the buttons on the steering wheel to navigate to the maintenance menu, select "engine oil" or "oil filter" (depending on what you want to reset), and then update the mileage or reset the reminder.
Here's a more detailed breakdown:
Turn the ignition to the "ON" position: without starting the engine.
Locate the information display and the buttons to navigate it.
You'll likely use buttons on the steering wheel to scroll through the menus.
Navigate to the "Maintenance" or "Service" menu.
Select "Engine Oil" or "Oil Filter": depending on which reminder you want to reset.
Update the mileage or reset the reminder.
The specific steps may vary slightly depending on your Outback's exact configuration, but generally involve confirming the reset with a button press.
