11237
Car Maintenance Tips & Routines
1 Inlägg
19 april 2025
Hi! I'm wondering how often you service your cars and which parts you usually replace during each service? Do you have any tips on what absolutely shouldn't be forgotten?
3 346 Inlägg
19 april 2025
I?m doing my cars at least once per year or every 10-15k.. so once every 6 months usually.
That includes replacing the oil, oil filter, and cabin air filter.
For other filters and maintenance I just refer to the owners- or service manual and replace the stuff I feel like replacing.
Remember that a lot of stuff with recommended intervals is just a way to upsell the customers.
Take brake fluid for example, almost every manufacturer recommends it to be replaced every other year when in reality you should probably be replacing it every 4-5 years.
Just make sure to do the engine oil and filter once every 15k and you?ll be allright.
Make sure to do the timing belt at its intervals.
Don?t run cheap oil in your engine, use one from a reputable manufacturer with the correct specifications for your engine. (You can check the specs at mpmoil.se).
Senast redigerat av Jesper328 (19 april 2025)
