11758
Forza Motorsport 3-tråden
244 Inlägg
4 september 2011
#2781
Ibland kan det vara så att jag inte minns det jag kommer ihåg.
Lat Perfektionist
6 359 Inlägg
4 september 2011
#2782
Olsson92 skrev:
menar du denna? smile
http://electronicfirst.com/
Ah, tack!
1 422 Inlägg
4 september 2011
#2783
Hörni gott forza folk! smile Kan man göra en ny användare på xboxet och få behålla alla bilar och grejer på den? Vill kunna lira live med er igen sad
Lat Perfektionist
6 359 Inlägg
4 september 2011
#2784
Angerwound has found a method of transferring your Savegames between profiles, it DOES NOT however work for Achievements and you will need a Memory Unit. Also you will need to delete the profile the save games came from.
-Insert the Memory Unit and go into the Xbox Dashboard
-In The Xbox Dashboard move to the blade furthest to the right
-Select: Memory --> Hard Drive --> Games --> The profile with the game save you want --> The game --> The game save --> COPY
-Repeat the last step for each save game you'd like to copy
-Remove the memory card
-Select: Memory --> Hard Drive --> Gamer Profiles --> The profile(s) the game save(s) came from --> DELETE
-log out of all profiles
-log into the profile you'd like to move the save games to
-insert the Memory Unit back into the console
-Select: Memory --> Memory Unit with the save games --> Select "Unrecognized Profile" --> Select the Game for the save game you want --> Select the Game Save you want --> COPY --> Select the Hard Drive
***Again I'd like to point out that the above will only copy game progress (NOT Achievements or anything else), It requires a Memory Unit, and it requires that the profile the Games saves came from is destroyed.
Hittade det på Google, har inte provat själv dock
Senast redigerat av LeafBox (4 september 2011)
6 767 Inlägg
5 september 2011
#2785
Malheus skrev:
Nu är jag snäll och säger till i god tid för att folk ska ha råd..Motorsport är dyrt big_smile
AMERICAN RACING
Måndag och Tisdag kl 21 (5/9 + 6/9)
Endast amerikanska bilar, B klass på måndag och A klass på tisdagen, bakhjulsdrift!
Bara amerikanska banor kommer köras
Uppvärmning med drifting/lekstuga 5minuter innan ( Börjar leka runt 20:50)
B klass - Måndag
A klass - Tisdag
INGA bil byten mellan racen och vi avslutar bägge gångerna med ett muskelbils race..minimum A klass, max S klass. På ringen
Det är inte okej att bara köra sista racet
De/Dem
825 Inlägg
5 september 2011
#2786
Beställde Forza Motorsport 4 Collectors Edition nu från Webhallen smile
Riktiga Bilar Kommer Från USA *****____________________
Bitter optimist.
1 561 Inlägg
5 september 2011
#2787
skäms nästan, jag har faktiskt inte förbeställt än :$
förbeställde Fm3 och har collectors edition i 2an o 3an
Senast redigerat av Stoner_fuzz (5 september 2011)
Lat Perfektionist
6 359 Inlägg
5 september 2011
#2788
Äh, jag har inte bokat heller, och jag tänker snåla på med den vanliga varianten tongue
123 Inlägg
5 september 2011
#2789
kommer inte kunna vara med ikväll har massa annat å göra, kanske imorn :p
356 Inlägg
5 september 2011
#2790
Måste ringen vara rwd muskelbil, eller kan man typ köra trimmad srt4?
6 767 Inlägg
5 september 2011
#2791
RWD muskel
De/Dem
Lat Perfektionist
6 359 Inlägg
5 september 2011
#2792
Malheus skrev:
RWD muskel
Damn, 4 real?
Skulle nämnts att det fanns nån slags åldersgräns isf tycker jag hmm
Edit:
Ah, näe. på ringen, ja dåså. Då klarar jag mej tongue
Senast redigerat av LeafBox (5 september 2011)
356 Inlägg
5 september 2011
#2793
Funkar de med en challenger 09a då? Eller old muscle, typ som i kaoset?
356 Inlägg
5 september 2011
#2794
Oi, ingen inne än? yikes
Lat Perfektionist
6 359 Inlägg
5 september 2011
#2795
Jag sitter och väntar på att Malheus ska komma ihåg att klockan är 21 och slänga upp en server ;D
6 767 Inlägg
5 september 2011
#2796
Det tar lite längre tid att stå på andra sidan stan och ta sig hem ifall man kör Alfa big_smile
De/Dem
Ljuva 90-tal
1 128 Inlägg
5 september 2011
#2797
Är med imorgon istället.
Nöjeskör närproducerat
volvolover
667 Inlägg
6 september 2011
#2799
Det är inte hastigheten som dödar, det är smällen
Lat Perfektionist
6 359 Inlägg
6 september 2011
#2800
Får se om jag hinner/orkar vara med idag hmm
Har haft den sjukaste dagen tongue
